Prostate examination. 😲
- Cousin Jack
- Has thanked: 3003 times
- Been thanked: 2522 times
- Has thanked: 8036 times
- Been thanked: 5694 times
Re: Prostate examination. 😲
Can't put it better than that!the_priest wrote: Sat Mar 19, 2022 6:20 pm Glad it was caught in time and that they say they can treat it. May your treatment be swift, pain free and fully effective.
Hope they get you sorted with minimum bother.
(I know what my test results are and NOT because they've been in contact to tell me. 'cos they haven't
- ogri
- Has thanked: 1274 times
- Been thanked: 337 times
Best wishes, hope the reaming isnt too enjoyable
Stay chilled, sometimes the stress can do more damage than the disease!
Saga Lout
- Has thanked: 600 times
- Been thanked: 749 times
I've already had the finger up, that was the easy bit.Horse wrote: Sat Mar 19, 2022 6:41 pmftfyslowsider wrote: Sat Mar 19, 2022 5:56 pmFinger up, saga. GWS.Saga Lout wrote: Sat Mar 19, 2022 5:12 pm Well. I got the results of the biopsy yesterday and it's bad news and good news.
Bad news: yes, it's cancer.
Good news: they should be able to cure it.
*Wanders off whistling "Always Look On the Bright Side Of Life".![]()
Best wishes, SL
Saga Lout
Actually, I'm surprisingly unstressed. Maybe that will change as the treatment gets under way. I'll have to wait and see.ogri wrote: Sat Mar 19, 2022 8:51 pm Best wishes, hope the reaming isnt too enjoyable
Stay chilled, sometimes the stress can do more damage than the disease!![]()
- Has thanked: 7620 times
- Been thanked: 5929 times
IIRC you mentioned umpteen biopsies? If so it's surprising there's anything left ...
- Felix
- Has thanked: 714 times
- Been thanked: 2039 times
Yeah, got the wiggly finger a week or so ago. Ill presume im OK as nothing was said.Saga Lout wrote: Sat Mar 19, 2022 11:25 pm Thanks all for your good wishes.![]()
And if you're an old git and haven't had your prostate checked, you know what to do.
I checked my own results, as they did bloods and urine, on Patient Access as they didn't contact me either.
Jeez. Read that far and thought that you'd done your own examination
Eeewww! Sort of auto-Sooty!Horse wrote: Sun Mar 20, 2022 8:34 amJeez. Read that far and thought that you'd done your own examinationCount Steer wrote: Sun Mar 20, 2022 8:26 amI checked my own ...Felix wrote: Sun Mar 20, 2022 12:10 am
Yeah, got the wiggly finger a week or so ago. Ill presume im OK as nothing was said.![]()
- gremlin
- Has thanked: 1102 times
- Been thanked: 5881 times
Docca
- Has thanked: 729 times
- Been thanked: 1436 times
Relieved it’s been caught and can be treated. That’s excellent news ( IYSWIM).
I had my MRI 9 days ago. Not heard anything yet, but can take 2 weeks.
- Bigyin
- Has thanked: 1436 times
- Been thanked: 2738 times
Hope all is betterer soonSaga Lout wrote: Sat Mar 19, 2022 11:25 pm Thanks all for your good wishes.![]()
I have no symptoms at all but you lot have got me thinking if i need a 55th birthday treat of a finger up the bum check later this year ....by a medical professional of course
- gremlin
At 55 I don't think you can afford to be picky.....Bigyin wrote: Mon Mar 21, 2022 6:12 pmHope all is betterer soonSaga Lout wrote: Sat Mar 19, 2022 11:25 pm Thanks all for your good wishes.![]()
And if you're an old git and haven't had your prostate checked, you know what to do.![]()
I have no symptoms at all but you lot have got me thinking if i need a 55th birthday treat of a finger up the bum check later this year ....by a medical professional of course![]()
Saga Lout
OK. Time for an update. Here goes, it might give you an idea what to expect if you have to go through it:
The treatment started in April with a course of Bicalutamide tablets: one a day for 28 days.
Two weeks into that I had the first of what will be six injections of Decapeptyl which reduces testosterone. I was told I might get some of the symptoms that ladies of a certain age experience when the menopause hits. I say "some", I'm pretty sure that I'm not likely to find my periods stopping.
I do, however, suffer from hot flushes and cold sweats. Most disconcerting.
Four weeks ago I started radiotherapy. The instructions are quite strict in that I had to be well hydrated, then an hour before the treatment time empty my bladder then drink 350ml of water. They wanted me to have a full(ish) bladder and an empty(ish) bowel so they supplied a load of micro-enemas which I had to use for the first two weeks of the radiotherapy. I've never had so much stuff shoved up my bum.
For the first couple of weeks they did an ultrasound scan to make sure my bladder was as full as it should be. A couple of times I had to go back to the waiting area and drink a cup or two of water.
A month before the radiotherapy started I went to the hospital, they put me on the table, lined me up in the right position and tattooed three dots, one on each hip and one on my belly.
The radiotherapy session itself takes less than 5 minutes, but first the nurses have to line you up on the table using the tattooed dots. they then go out of the room and the machine rotates around you until you're suitably irradiated.
Side effects of the raiotherapy:
I now know what they mean by the burning sensation. It's not really a burning sensation, it's more an intensification of the overwhelming urge to have a piss, but because it takes so long to get started and the flow is now very slow that feeling just builds and builds very uncomfortably.
Because the prostate is so close to the bowel I was warned that some damage to the bowel was almost inevitable and to expect some bleeding. That has happened.
I'm assured that these side effects should start to go away during the next 7 to 14 days.
And that's about it. I had my last radiotherapy session today.
Reports of my demise are premature.
- Has thanked: 602 times
- Been thanked: 4528 times
Where abouts are you being treated, my minion's wife manages cancer treatment at Colchester and Ipswich hospitals
- Been thanked: 15488 times
Saga Lout
Colchester. Nothing but praise for all the staff there.Le_Fromage_Grande wrote: Tue Aug 23, 2022 8:51 pm Where abouts are you being treated, my minion's wife manages cancer treatment at Colchester and Ipswich hospitals
- Has thanked: 1080 times
- Been thanked: 1010 times
