DH Gipsy engine 1/4 scale
- hilldweller
- Has thanked: 73 times
- Been thanked: 51 times
Re: DH Gipsy engine 1/4 scale
Oil lines , i thought these would be available to buy , some parts are steam fittings but the unions
and banjo bolts needed to be made.
I turned the union parts out of brass
Then started to silver solder them together
I made a jig to replicate the hole spacing on the engine and soldered them together with 1/8 copper pipe
Also made some pipe work using the steam fittings
Just a quick side note, when i made the spark plugs my Gf said she thought they would make
quirky ear rings . So while i was in the mood i made a couple of even smaller plugs and fitted
then to some ear fittings, because i'm good like that.
Sump Plug?kendo57 wrote: Mon May 25, 2020 9:09 pm Just a quick side note, when i made the spark plugs my Gf said she thought they would make
- Yambo
- Has thanked: 512 times
- Been thanked: 1403 times
Great stuff kendo!
I've been away for a bit doing a number of different jobs so I've just been playing catch up. One of the jobs was to bend a bit of copper or brass tube - I used brass as I couldn't find the copper (although I found it a bit later) and flare the ends. Now metal is not really my thing, I can do bits and pieces but much prefer wood.
My problem is preventing the tube from flattening as I bent it - you clearly don't have this problem, do you have a brake pipe bender/flarer tool? I simply heated the tube and bent it around a pit of broom handle with a bit of thick copper wire inside to minimise the flattening. My first version, with 3 strands of copper wire inside is laying around somewhere - bent quite nicely but still with 3 strands of copper wire stuck inside.
What are they for? They're simply guides for the sail control sheets. An update and some pictures going on the boat shed thread later.
- GuzziPaul
- Has thanked: 59 times
- Been thanked: 195 times
If you have to do it again try filling the pipe with fine sand instead, you won't have a problem getting that out.Yambo wrote: Tue Jun 02, 2020 11:11 am My problem is preventing the tube from flattening as I bent it - you clearly don't have this problem, do you have a brake pipe bender/flarer tool? I simply heated the tube and bent it around a pit of broom handle with a bit of thick copper wire inside to minimise the flattening.
Or tinman's solder. Mind you that makes it hard to bend.
You get it out by melting the solder out. I wonder whether you might be able to use candlewax to achieve something similar.
You can of course get brake pipe bending tools from machinemart etc.
Ian.
1952 Norton ES2
1952 Norton ES2
- Yambo
Never heard of that!
It worked reasonably well with the thick copper wire, a bit of flattening but the line runs freely through it and no one will see it so it's job done as far as I'm concerned!iansoady wrote: Wed Jun 03, 2020 11:25 amYou get it out by melting the solder out. I wonder whether you might be able to use candlewax to achieve something similar.
I'm 2000 miles away from the nearest machine mart. I could get one on line here but for two bits of pipe it wasn't worth the money, plus all of the kits I saw had tooling starting at thicker pipe than I've got. I wasn't sure how that would work so didn't bother. I didn't use sand either as getting hold of fine grain sand was also not a simple matter. I'm under house arrest and even when could go out, hunting around for a spoonful of fine sand was well down the list of priorities.iansoady wrote: Wed Jun 03, 2020 11:25 amYou can of course get brake pipe bending tools from machinemart etc.
The tube i used was the coiled 'microbore' type which is soft and bends easy.
Also i was only using 6mm pipe.
The copper 'work' hardens quickly so you need to re heat to red frequently. I used a piece of
copper wire like you for the tight bends .
I watched a film of a company making brass musical instruments and they filled the tube
with water then froze it before bending.
Time i made a stand , a mate gave me a chunk of alloy a while back , apparently it was used to secure
overhead cables and they inspect and replace them regularly . So i thought i might be able to make a
stand out of it.
So i attacked it with my angle grinder and a cutting disc first ,, alloy can be a right pig to cut.
Then spent an age on the mill wishing i had never started .
Couple of alloy rods and some engine mounts
stand out of it.
I have now filled with oil and primed the pump. After turning the engine over with a drill i was happy
to see oil pumping through the oil lines . I did have a few small leaks but easily fixed.
So here are some pics of were i am at , need to make the dummy magnetos next and then come
up with an ignition system .
Cool as.
- hilldweller
Can we have a picture with something in it to show the real world scale of it please.
Brian
hilldweller wrote: Fri Jun 19, 2020 9:44 pm Can we have a picture with something in it to show the real world scale of it please.
