The iconic superbike : Yamaha YZF-R1
Has thanked: 2908 times
Been thanked: 1678 times
Re: The iconic superbike : Yamaha YZF-R1
Mr. Dazzle wrote: Sun Jan 24, 2021 8:08 am More valves generally also means more valve area, which is one of the big reasons they do it. The valves are circular, so if you imagine fitting circular valves into a circular cylinder head you can 'cover' more of the bore with a greater number of smaller valves.
That in turn means you have less restriction on gas getting jn/out of the cylinders. One of the limitations on engine power is how quickly and easily you can get the fuel in and the exhaust out. More valve area means you can shove it in/out more quickly so you push the revs higher and the peak power up.
5v doesn't intrinsically make an engine peaky, bit it does facilitate tuning for high peak power at peak revs, which has the effect of making the engine revvy. Chicken and egg kinda thing.
You can also close the exhaust valves sooner, which means less fresh charge chasing the burnt gases out the exhaust ports.
That's why the FZ was so frugal. My 1990 version averaged 55 mpg, would hit 60 mpg without too much trouble and got close to 70 mpg on one Bank Holiday Monday run back across France when I couldn't find an open filling station for 200 miles. Nicest engine on anything I've owned.
My 92 WN GSX-R750 was more powerful (according to the spec sheet) and was far more peaky, but struggled to top 40 mpg. One German autobahn run got it down to just under 30 mpg.
Has thanked: 12607 times
Been thanked: 8537 times
The Spin Doctor wrote: Wed Apr 21, 2021 12:21 pm
You must ride like a gurl. I used to get my GSXR1000 down to 17 mpg
Yorick wrote: Wed Apr 21, 2021 12:23 pm
Yeah, but you have bigger bores than me :)
Bigjawa
Has thanked: 225 times
Been thanked: 969 times
Post by Bigjawa »
Most of the Slingshot and WN on GSXRs had carbs that were far too big, same with the 1100.
The Spin Doctor wrote: Wed Apr 21, 2021 12:25 pm
Nah, you ride like a gurl, I've never got 50mpg out of an FZ, and my early R1 used to do about 20mpg, I ride like a twat.
Le_Fromage_Grande wrote: Thu Apr 22, 2021 7:46 am
Looks like I'm outvoted. I'll get the wig ;)
Tricky
Has thanked: 3043 times
Been thanked: 3309 times
Post by Tricky »
Seems an appropriate opportunity for a bit of picture-whoring to me :)
I bought mine brand new in 1999 , was the bike I did my first ever trackday on back in the days when I used to ride to them, it gave me 15k trouble free miles of real fun before I sold it :thumbup:
Bigjawa wrote: Wed Apr 21, 2021 9:54 pm
That's probably correct, it's led to people running huge flat slides on mildly tuned big Zs and then complaining about throttle response
Scootabout
Has thanked: 587 times
Been thanked: 373 times
Post by Scootabout »
It's the superbike whose name springs to mind first. Possibly because "R1" is a lot quicker to say than "GSXR1000" for example.
Same number of syllables as Gixer tho'
