So while I'm waiting to stick the VFR on the dyno, and the weather is still shit, I thought I'd bugger about with the LC. Just because.
The LC has a YSS shock on it, which is a massive improvement on the 40 year old thing that supported the rear of the bike before. But after a fair amount of running, I've realised that a) the spring is a bit on the harsh side for my tender little botty and b) I'd like some more weight on the front to make it feel a little less vague.
As regards the spring, YSS ship the shock with an 80 Nm (or is that N/mm?) item. They also offer a 70 and a 90 spring in the same sizes for lighter and heavier riders respectively. So I've placed an order for a 75 Nm with a local spring supplier, just to be a fussy bastard. Delivery should be mid-March.
To try and fix the perceived 'weight on front' problem, I've acquired some 25mm alloy round bar and handed it to my local engineering place, along with a CAD drawing and asked them to make it happen. This is what I got back:
- DSCF4017.JPG (567.04 KiB) Viewed 1001 times
These fit in between the top shock eye and the shock body and increase the overall length of the shock by anything between 25 and 40mm, thereby jacking the back end of the bike up by a similar amount. The piece with the shorter nose gives a minimum increase of 25mm in shock length, the one with the longer nose and thin nut gives a minimum increase of 30mm in shock length. If you really wanted to you could increase the shock length by at least another 15mm, but frankly it's all getting a bit silly at those settings. This is a pic of the shock with short extension mounted on the bike:
- DSCF4002.JPG (412.2 KiB) Viewed 1001 times
To be honest, the extension piece with the short nose is probably at the outer limits of sensible modification. With that fitted, the centre stand is largely redundant as it needs to be stood on a piece of 18mm ply to actually get the rear wheel off the ground. I'm also planning to drop the forks through the yokes by 10mm to lower the front and hopefully bring the centre stand back into use. Thankfully the LC also has a side stand, but the bike now sits at quite a jaunty angle when using that (see below). At least it won't blow over in the wind...
- DSCF4014.JPG (729.74 KiB) Viewed 1001 times
And after all this I still don't know what effect these mods will have on the handling. I'll learn that in due course... But all the mods are completely reversible, so not all is lost if it fails horribly...
