- derek badger
- Has thanked: 1090 times
- Been thanked: 1748 times
- rodbargee
- Has thanked: 397 times
- Been thanked: 1114 times
- Contact:
- rodbargee
- Contact:
- derek badger
Snowmobile torque convertor, both cranks linked by chain drive. Mind your bell bottoms...
- Has thanked: 245 times
- Been thanked: 1228 times
- Contact:
- Has thanked: 7619 times
- Been thanked: 5929 times
- Has thanked: 602 times
- Been thanked: 4528 times
That photo is 1980s, fwd Ford Escort in the backgroundderek badger wrote: Thu Dec 10, 2020 9:59 pmSnowmobile torque convertor, both cranks linked by chain drive. Mind your bell bottoms...
- derek badger
Isn't it just? I prefer it without the faring to be honest. I'd love something similar to this with lights/road legal.
That's me done....derek badger wrote: Fri Dec 11, 2020 3:03 pmIsn't it just? I prefer it without the faring to be honest. I'd love something similar to this with lights/road legal.
Is the left header kinked in for ground clearance? As it has separate header & exhaust (I hesitate to say 'silencer') for each cylinder, presumably they don't all need to be the same length? Or is it, that for two strokes, the entire thing has to be a certain length?
Well,sometimes just because you can doesn't mean you should..
Link to story.
http://www.bikebound.com/2019/05/12/kaw ... afe-racer/
Link to story.
- Has thanked: 222 times
- Been thanked: 788 times
Dont think so Julian....Julian_Boolean wrote: Fri Dec 11, 2020 2:08 pmThat photo is 1980s, fwd Ford Escort in the backgroundderek badger wrote: Thu Dec 10, 2020 9:59 pmSnowmobile torque convertor, both cranks linked by chain drive. Mind your bell bottoms...
- derek badger
I think it's Australian. Ford Falcon estate or similar?David wrote: Fri Dec 11, 2020 3:28 pmDont think so Julian....Julian_Boolean wrote: Fri Dec 11, 2020 2:08 pmThat photo is 1980s, fwd Ford Escort in the backgroundderek badger wrote: Thu Dec 10, 2020 9:59 pm
- Been thanked: 2727 times
On a 2T they all need to be the same length if you want performance. It's less an engine and more of a musical instrument.Horse wrote: Fri Dec 11, 2020 3:11 pm Is the left header kinked in for ground clearance? As it has separate header & exhaust (I hesitate to say 'silencer') for each cylinder, presumably they don't all need to be the same length? Or is it, that for two strokes, the entire thing has to be a certain length?
Read about Walter Kaaden's work at DKW.
Looks like a US spec Escortderek badger wrote: Fri Dec 11, 2020 3:32 pmI think it's Australian. Ford Falcon estate or similar?David wrote: Fri Dec 11, 2020 3:28 pmDont think so Julian....Julian_Boolean wrote: Fri Dec 11, 2020 2:08 pm
https://en.wikipedia.org/wiki/Ford_Esco ... _Wagon.jpg
They need to be the same frequency I think, not necessarily the same length? They look like they're different diameters.cheb wrote: Fri Dec 11, 2020 3:41 pm
Ducati made a marketing song and dance about using different bore headers on similar grounds ISTR.
Depends on what you want to do with a two stroke, for instance, RD500s run the front cylinders in a different tune to the rear cylinders to boost the mid range, but they are effectively two engines joined together on a common clutch, whether you could get away with this on a single crank, I don't know, I think that eventually you'd twist the crank on it's centre pin. But for cylinders to run the same on any engine the exhausts have to have the same resonant qualities on each cylinder, there's a number of ways you can achieve this, especially on two strokes, four strokes are much easier to work out, where it's just the pipe length, diameter and taper that need to be taken into account, bends don't have a massive effect so long as you measure the length correctly - you have to average the inside and outside lengths of the bend - all this is theoretical, real world results may differ, and you can't beat someone with experience making you an exhaust.Mr. Dazzle wrote: Fri Dec 11, 2020 4:10 pmThey need to be the same frequency I think, not necessarily the same length? They look like they're different diameters.cheb wrote: Fri Dec 11, 2020 3:41 pm
- Contact:
Because some cylinders are more powerful than others?Julian_Boolean wrote:I think that eventually you'd twist the crank on it's centre pin
In any multi cylinder engine, one cylinder is producing peak effective pressure and torque, while other cylinders are at negative pressure and torque.
