derek badger
Has thanked: 769 times
Been thanked: 1135 times
Post by derek badger »
rodbargee
Has thanked: 353 times
Been thanked: 980 times
Post by rodbargee »
rodbargee
Post by rodbargee »
derek badger wrote: Thu Dec 10, 2020 5:01 pm Image
You mad bastard! springs to mind but fun.
derek badger
rodbargee wrote: Thu Dec 10, 2020 8:34 pm
Snowmobile torque convertor, both cranks linked by chain drive. Mind your bell bottoms...
Has thanked: 261 times
Been thanked: 1265 times
Has thanked: 6191 times
Been thanked: 5087 times
Genuine LOL :D
derek badger wrote: Thu Dec 10, 2020 9:59 pm
That photo is 1980s, fwd Ford Escort in the background
derek badger wrote: Thu Dec 10, 2020 5:02 pm Image
Nice
Weird
derek badger
Julian_Boolean wrote: Fri Dec 11, 2020 2:09 pmNice
Isn't it just? I prefer it without the faring to be honest. I'd love something similar to this with lights/road legal.
Has thanked: 9828 times
Been thanked: 10145 times
derek badger wrote: Fri Dec 11, 2020 3:03 pm
That's me done....
Is the left header kinked in for ground clearance? As it has separate header & exhaust (I hesitate to say 'silencer') for each cylinder, presumably they don't all need to be the same length? Or is it, that for two strokes, the entire thing has to be a certain length?
Well,sometimes just because you can doesn't mean you should..
Link to story.
http://www.bikebound.com/2019/05/12/kaw ... afe-racer/
Has thanked: 218 times
Been thanked: 689 times
Julian_Boolean wrote: Fri Dec 11, 2020 2:08 pm
Dont think so Julian....
derek badger
David wrote: Fri Dec 11, 2020 3:28 pm
I think it's Australian. Ford Falcon estate or similar?
Been thanked: 2617 times
Horse wrote: Fri Dec 11, 2020 3:11 pm Is the left header kinked in for ground clearance? As it has separate header & exhaust (I hesitate to say 'silencer') for each cylinder, presumably they don't all need to be the same length? Or is it, that for two strokes, the entire thing has to be a certain length?
On a 2T they all need to be the same length if you want performance. It's less an engine and more of a musical instrument.
Read about Walter Kaaden's work at DKW.
derek badger wrote: Fri Dec 11, 2020 3:32 pm
Looks like a US spec Escort
https://en.wikipedia.org/wiki/Ford_Esco ... _Wagon.jpg
Has thanked: 2551 times
Been thanked: 6245 times
cheb wrote: Fri Dec 11, 2020 3:41 pm
They need to be the same frequency I think, not necessarily the same length? They look like they're different diameters.
Ducati made a marketing song and dance about using different bore headers on similar grounds ISTR.
Mr. Dazzle wrote: Fri Dec 11, 2020 4:10 pm
Depends on what you want to do with a two stroke, for instance, RD500s run the front cylinders in a different tune to the rear cylinders to boost the mid range, but they are effectively two engines joined together on a common clutch, whether you could get away with this on a single crank, I don't know, I think that eventually you'd twist the crank on it's centre pin. But for cylinders to run the same on any engine the exhausts have to have the same resonant qualities on each cylinder, there's a number of ways you can achieve this, especially on two strokes, four strokes are much easier to work out, where it's just the pipe length, diameter and taper that need to be taken into account, bends don't have a massive effect so long as you measure the length correctly - you have to average the inside and outside lengths of the bend - all this is theoretical, real world results may differ, and you can't beat someone with experience making you an exhaust.
Julian_Boolean wrote:I think that eventually you'd twist the crank on it's centre pin
Because some cylinders are more powerful than others?
In any multi cylinder engine, one cylinder is producing peak effective pressure and torque, while other cylinders are at negative pressure and torque.
