Julian_Boolean wrote: Fri Nov 27, 2020 10:21 am I've seen one, a yellow one, they're not as ugly in real life, they're still fugly though
I've seen loads, just never one with that fly screen.
KungFooBob wrote: Fri Nov 27, 2020 10:56 am
Loads, is there a chapter of the Bimota Mantra owners club in Barnsley?
I am quite well travelled you know.
KungFooBob wrote: Fri Nov 27, 2020 11:38 am I am quite well travelled you know.
You've been to Thurgoland?
Julian_Boolean wrote: Fri Nov 27, 2020 11:44 am You've been to Thurgoland?
I pass through it to get to my sisters house in Penistown.
Been thanked: 2727 times
Are these places anywhere near Blubberhouses?
Just in case 1 steering damper isn't enough
KungFooBob wrote: Fri Nov 27, 2020 12:25 pm
My sister used to live in Armitage Bridge before she moved to the Darkside (Wigan)
Has thanked: 10959 times
Been thanked: 3995 times
weeksy wrote: Fri Nov 27, 2020 1:22 pm Just in case 1 steering damper isn't enough
WT-A-F ??
Anyone notice that none of them are connected to the frame, so they're not actually doing anything!
derek badger
Has thanked: 1090 times
Been thanked: 1748 times
Post by derek badger »
KungFooBob wrote: Fri Nov 27, 2020 4:20 pm
Never mind that. What's the 2nd throttle on the LH side for?!
Makes for easier wheelying, the bar rotates in your hand.
A different take on Mods and the extra lights and mirrors fitted to scooters maybe.
There's also something on the rh fork leg.
Probably just as well they're not connected, might be a bit slow steering otherwise :D
Has thanked: 1059 times
Been thanked: 1646 times
I did my radiograpic testing qualification's* at a place called Penistone, near Sheffield.
The place I trained and tested at was just past the railway bridge.
Same place?
*Long time ago, when I was a weld inspector and before I took up wood butchery.
The training was interesting but the crawling about in pressurised steam boilers inspecting 25% of furnace end seams less so.
Yup Penistone = Penistown.
..and it's much nearer Barnsley than Sheffield.
KungFooBob wrote: Fri Nov 27, 2020 5:32 pm ..and it's much nearer Barnsley than Sheffield.
I got a lift there so was in effect parachuted into the place with buggerall navigational clues.
The driver knew the way and I just listened to his Blood Sugar Sex Majik album by the Chilli Peppers.
Anyway, here's a not so random pic I found amongst my Barbon Hillclimb photos.
IIRC the rider had a disability to do with his left hand so didn't have a left bar at all.
Seemed to manage stuff just fine though.
G.P
Has thanked: 1994 times
Been thanked: 1283 times
Post by G.P »
derek badger wrote: Fri Nov 27, 2020 4:25 pm
BELLWOOD ! :D
Druid
Has thanked: 351 times
Been thanked: 1106 times
Post by Druid »
Skub wrote: Sat Nov 28, 2020 4:18 pm https://www.facebook.com/marketplace/it ... =undefined
Where would you start....
Hacksaw, hammer, skip...
derek badger
G.P wrote: Sat Nov 28, 2020 6:05 pm
BELLWOOD ! :D
Exactly what sprang to mind when I saw it!!!🤣
