I've seen loads, just never one with that fly screen.Julian_Boolean wrote: Fri Nov 27, 2020 10:21 am I've seen one, a yellow one, they're not as ugly in real life, they're still fugly though
- Been thanked: 9495 times
- Has thanked: 602 times
- Been thanked: 4528 times
Loads, is there a chapter of the Bimota Mantra owners club in Barnsley?KungFooBob wrote: Fri Nov 27, 2020 10:56 amI've seen loads, just never one with that fly screen.Julian_Boolean wrote: Fri Nov 27, 2020 10:21 am I've seen one, a yellow one, they're not as ugly in real life, they're still fugly though
- Been thanked: 2730 times
- Has thanked: 6125 times
- Been thanked: 15493 times
My sister used to live in Armitage Bridge before she moved to the Darkside (Wigan)KungFooBob wrote: Fri Nov 27, 2020 12:25 pmI pass through it to get to my sisters house in Penistown.
- Has thanked: 10964 times
- Been thanked: 3995 times
Anyone notice that none of them are connected to the frame, so they're not actually doing anything!
- derek badger
- Has thanked: 1090 times
- Been thanked: 1752 times
Never mind that. What's the 2nd throttle on the LH side for?!KungFooBob wrote: Fri Nov 27, 2020 4:20 pmAnyone notice that none of them are connected to the frame, so they're not actually doing anything!
Makes for easier wheelying, the bar rotates in your hand.
A different take on Mods and the extra lights and mirrors fitted to scooters maybe.
There's also something on the rh fork leg.
Probably just as well they're not connected, might be a bit slow steering otherwise
- Has thanked: 1059 times
- Been thanked: 1646 times
I did my radiograpic testing qualification's* at a place called Penistone, near Sheffield.
The place I trained and tested at was just past the railway bridge.
Same place?
*Long time ago, when I was a weld inspector and before I took up wood butchery.
The training was interesting but the crawling about in pressurised steam boilers inspecting 25% of furnace end seams less so.
Yup Penistone = Penistown.
..and it's much nearer Barnsley than Sheffield.
I got a lift there so was in effect parachuted into the place with buggerall navigational clues.
The driver knew the way and I just listened to his Blood Sugar Sex Majik album by the Chilli Peppers.
Anyway, here's a not so random pic I found amongst my Barbon Hillclimb photos.
IIRC the rider had a disability to do with his left hand so didn't have a left bar at all.
Seemed to manage stuff just fine though.
- G.P
- Has thanked: 1994 times
- Been thanked: 1283 times
BELLWOOD !derek badger wrote: Fri Nov 27, 2020 4:25 pmNever mind that. What's the 2nd throttle on the LH side for?!KungFooBob wrote: Fri Nov 27, 2020 4:20 pmAnyone notice that none of them are connected to the frame, so they're not actually doing anything!
- Druid
- Has thanked: 351 times
- Been thanked: 1106 times
Hacksaw, hammer, skip...Skub wrote: Sat Nov 28, 2020 4:18 pm https://www.facebook.com/marketplace/it ... =undefined
Where would you start....
- derek badger
Exactly what sprang to mind when I saw it!!!G.P wrote: Sat Nov 28, 2020 6:05 pmBELLWOOD !derek badger wrote: Fri Nov 27, 2020 4:25 pmNever mind that. What's the 2nd throttle on the LH side for?!KungFooBob wrote: Fri Nov 27, 2020 4:20 pm
Anyone notice that none of them are connected to the frame, so they're not actually doing anything!![]()
