The Best Looking Bike Ever?
- Has thanked: 1051 times
- Been thanked: 860 times
- Has thanked: 3255 times
- Been thanked: 1737 times
Re: The Best Looking Bike Ever?
That DB2 based special on here the other year was stunning.& as far as I can tell unique
For me it has all the right ingredients, a aircooled twin cylinder motor in a steel tubed frame,light weight & no gadgets/clutter
I wouldn't park it in the garage,it would be in the lounge so that I could look at it when I'm not out riding it.
- Has thanked: 221 times
- Been thanked: 878 times
You've never seen a half faired one. I love the naked EFE, but prefer the old ET.
There's hydrogen buses in Belfast. The tanks are supposedly safe to 600 degrees. And they're surrounded by fibreglass that burns at something like 1200....Count Steer wrote: ↑Fri Dec 15, 2023 5:23 pmYup. I saw another thread about the bike but they do look like rocket engines.Rockburner wrote: ↑Fri Dec 15, 2023 5:16 pmThose are apparantly the hydrogen tanks... so if it got rear-ended then you may well get flames out the back!! (albeit briefly)Count Steer wrote: ↑Fri Dec 15, 2023 4:57 pm
Well, if flames came out of the back it would look epic.
(If it got rear ended, there'd be a big pop! and a lot of water. ).
First riot will be fun.
- Has thanked: 1507 times
- Been thanked: 1412 times
- Has thanked: 9828 times
- Been thanked: 10145 times
Tis lovely yes,maybe a close second to the original,but not nicer to my old lamps.
Well spotted.
- Has thanked: 4 times
- Been thanked: 1 time
- Has thanked: 1746 times
- Been thanked: 2085 times
Wow, I have literally given away classic bikes in better nick than that.
You wouldn't keep much apart from the frame and engine cases to get it registered
To be fair I guess mudguards must be like hens teeth now, the wheels don't look bad so it might be worth 500 quid but we both know its going to fetch a lot more
- Has thanked: 1829 times
- Been thanked: 1469 times
Mind you, it would be better with the X1 swingarm , thunderstorm heads and a better (Penske if possible) shock
- Has thanked: 261 times
- Been thanked: 1265 times
Yes, it’s not rocket science. Or is it?Count Steer wrote: ↑Fri Dec 15, 2023 4:57 pmWell, if flames came out of the back it would look epic.
Aren’t hydrogen flames hard to see though?
- Has thanked: 6376 times
- Been thanked: 4753 times
Yup. But I'm sure you could add something to make the flames purple or maybe bright red (strontium should do red iirc ).JackyJoll wrote: ↑Mon Dec 18, 2023 10:53 amYes, it’s not rocket science. Or is it?Count Steer wrote: ↑Fri Dec 15, 2023 4:57 pmWell, if flames came out of the back it would look epic.
An hour and forty left on the bidding and it's up to £1220Skub wrote: ↑Sat Dec 16, 2023 11:32 am @Ian What do you reckon,a light polish and we're done?
https://www.ebay.co.uk/itm/266568463756 ... 0667.m2042
I had an ET, good bike, but the GS1000E that had the same frame was better looking.
- Has thanked: 2405 times
- Been thanked: 3630 times
I can't believe that this bike is being touted as a possibility for 'Best looking bike ever'. Get a grip, FFS.Le_Fromage_Grande wrote: ↑Fri Dec 22, 2023 10:44 pmI had an ET, good bike, but the GS1000E that had the same frame was better looking.
It`s all about opinions. We all have one !mangocrazy wrote: ↑Fri Dec 22, 2023 11:39 pmI can't believe that this bike is being touted as a possibility for 'Best looking bike ever'. Get a grip, FFS.Le_Fromage_Grande wrote: ↑Fri Dec 22, 2023 10:44 pmI had an ET, good bike, but the GS1000E that had the same frame was better looking.
- Been thanked: 2617 times
