And now the large grey pachyderm lurking in the corner....
The bearing in the alternator cover. At the moment I cannot stop it failing every 250 miles, bang on, every time I replace it.
3 times now, 3 times.
I think I have found the cause but I'm not sure if I've fixed it and the only way, at the moment, I can see to be sure is to ride it and wait for it to fail. Which is a proper pain in the hole.
To recap, on the V-twin Ducati's - since time immemorial - there is a bearing that is an interference fit in the alternator cover and which slides over the end of the crankshaft and supports the end of the crankshaft to prevent any whip as a result of the flywheel not having absolutely perfect balance.
I've had genuine Ducati OEM and non Ducati aftermarket bearings fail, both at the same mileage. I've fitted the bearing in the cover and Nelly has fitted the bearing in the cover, both failed at the same mileage. After the 3rd failure, which wipes out the stator every time, I had to stop fucking around and get to the bottom of this.
Now, back in a previous career as an engineering consultant tribology used to be a specialism of mine. So I dug out an old FMEA I created for investigating bearing failures when the remains of the bearing don't allow detailed examination to determine cause of failure, like this one....
I went through everything it could possibly be and ruled most of them out - for example, going to the lengths of checking the balance of the flywheel, as it had been lightened, to make sure that wasn't out of balance and hammering the bearing - and one of the possible remaining causes could be excessive parasitic axial load.
The bearing used is a regular cartridge ball bearing, and bearings like this cannot cope with any significant difference in sideways force being exerted on the inner race compared to the outer race, and vice versa.
So, the bearing is fixed in place in the alternator cover and the alternator cover is, in turn, fixed in place to the crank cases. And the crank shaft is fixed in place in the crank cases as well. But there are tolerances in all of these parts, so to deal with these tolerances - and them not putting excessive parasitic axial load into the bearing - the inner race of the bearing is supposed to float from side to side on the crank so that there is no side loading at all.
This is the crank sticking out of the crank cases (the flywheel is removed, it is normally on the splines on the crankshaft. Ignore the mangled, off centre, thrust washer sitting on the face of the timing shaft drive gear, it's a common sight on Ducati's. Even out of the factory). The bearing sits on the smallest diameter part of the crankshaft, closest to the camera, and you can just see the chamfer on the end of the crankshaft that leads the bearing in.
I had the inner race of the last failed bearing and was idly looking at it and the crank and thought I'd slide it on the crank (something that you can't do normally because the bearing is in one piece and fitted in the alternator cover). I expected the race to slide along the crank until it hit the increase in diameter where the crankshaft stepped up to the flywheel nut threads.
Nope.
It stopped with about 5mm to spare and the lead in chamfer only just sticks out of the inner race.
Hmmmm, thinks I. That can't be right can it?
Remove the inner race and run my fingertip over the crank and there's a burr on one section of the crankshaft that is preventing the bearing from sliding on any more. Could that be it?
It makes sense. Because the flywheel is magnetic as soon as you start sliding the alternator cover on the stator - bolted to the inside of the cover - is grabbed by the flywheel and the cover is pulled on, normally taking it out of your hands. You then snug down the cover using the M6 bolts all around the edge of the cover. How would you be able to detect if the bearing inner race is snagged on the crankshaft and can't slide on as far as it needs to?
You can't. So the bearing is sitting there with the cover trying to press it into the engine, but the burr on the crankshaft is stopping it sliding on and hey presto, there's your excessive parasitic axial load.
I don't know for definite how the crank got the burr. If I had to guess I'd say that whoever fitted the non genuine Ducati bearing in the cover when I got the bike didn't have the correct tool for removing the cover and keeping everything nice and square/parallel..
...and in levering the cover off on the piss they damaged the crank shaft.
I've deburred the crank shaft and put it all together. But at the moment I'm still not certain the bearing has gone on far enough, the difference between correct and failing in 250 miles is going to be less than a mm. I may take it all apart again and give it some more thought....
...and fixed the cold starting issue.
