The Triumph
Has thanked: 19569 times
Been thanked: 4950 times
Re: The Triumph
the_priest wrote: Sun Apr 30, 2023 3:41 pm The headers have corrosion on them. I have managed to get them a bit better, but am not a garage queen. I want to ride the bike, not spend my time polishing it.
Good chance I've written this before but, when I got my first Blackbird, a really good mate had a pub and he said - come over on the weekend and we can polish both bikes (he had a green ZX9r).
My response was apparently unexpected - I've got a new bike, the sun will be shining and its weekend; what makes you think I'll be polishing and not riding!!! :lol: :lol: :lol: :lol:
Has thanked: 2289 times
Been thanked: 2673 times
Re: The Triumph
That was the first time the Muzzy had been off the bike since 2005. Removed it to clean the front of the engine :) The (mild steel) ZX11 headers just got the graphite stove polish treatment. Painted it on by brush, fired the bike up the next day & smoked out the garage. Most Americans have never heard of the stuff, told those who asked to "ask your grandmother".
Has thanked: 2098 times
Been thanked: 2558 times
Re: The Triumph
New Rear Indicators are now installed. This is no BMW!
A_morti
Has thanked: 412 times
Been thanked: 824 times
Re: The Triumph
Post by A_morti »
And yet those are the exact same indicators you will find on an f650gs single
Re: The Triumph
Done some more work. Soldered and heat shrink for the new waterproof connectors. Front indicators done.
Connectors at bike side done.
Loosely fitted to the bike (waiting for fan.) Indicators do work perfectly front and rear.
Just waiting for the fan to be delivered. Will check that coolant I have in stock is for aluminium blocks, if not, will buy some more.
Re: The Triumph
Fan arrived early! Wiped down, no rust. Fitted to radiator and then to the bike. Need to fit coolant hoses and add coolant, but that is for much later on as I have a hospital visit to go and make.
Re: The Triumph
Found I had no coolant, but filled it with water for now. Will MOT bike, flush radiator and refill with coolant. Sunny and bright tomorrow, so perfect weather for first ride of the year. Comes up to temp nicely, smoked a lot, but has not been run for so long in several months, so to be expected of a 59K engine. Fan comes on when temps get 1/3 of the way.
Re: The Triumph
the_priest wrote: Tue May 02, 2023 8:11 pm Found I had no coolant, but filled it with water for now. Will MOT bike, flush radiator and refill with coolant. Sunny and bright tomorrow, so perfect weather for first ride of the year. Comes up to temp nicely, smoked a lot, but has not been run for so long in several months, so to be expected of a 59K engine. Fan comes on when temps get 1/3 of the way.
I rebuilt dozens of 2-stroke racing engines and only used tap water.
Re: The Triumph
Not cold enough for coolant nor hot enough either at the moment. But coolant will be purchased and added once I get the time. Meetings from 9am this morning, so MOT will have to wait a bit and an afternoon meeting and walking the dog (much more important!).
wull
Has thanked: 979 times
Been thanked: 1858 times
Re: The Triumph
Post by wull »
Regardless of temps you want the coolant as it has additives that will stop the build up of rust and other stuff you don’t want that can potentially block up the water jackets.
But because it’s such a short time it will be fine and you’re flushing it out.
In my race bikes I used to run water all year ( you had to ) but would flush it before the winter lay up and add coolant then.
Re: The Triumph
Coolant makes the water wetter too (breaks the surface tension so it "wets" the surfaces more) and hence makes it cool better, but I doubt that's a factor here!
Re: The Triumph
Mr. Dazzle wrote: Wed May 03, 2023 8:51 am Coolant makes the water wetter too (breaks the surface tension so it "wets" the surfaces more) and hence makes it cool better, but I doubt that's a factor here!
In the US you used to be able to buy a product called 'water wetter' as a special coolant that was legal in race bikes.
Re: The Triumph
KungFooBob wrote: Wed May 03, 2023 8:53 am
Washing up liquid probably :D
The stuff which makes soap bubbly is often separate from the stuff which gives soap it's "wetting" property so you can add one without adding the other.
Re: The Triumph
Surfuctant. I just like the word.
wull
Re: The Triumph
Post by wull »
I’m sure it’s still available, they swore that it would make bikes run cooler.
Re: The Triumph
Nominally it will run cooler, but as with all these things if you're not set up to take advantage of it you won't notice.
Re: The Triumph
wull wrote: Wed May 03, 2023 9:07 am
You can get it in Euro Car Parts! As KFB says the Yanks use it in most race bikes, or did when I was reading US forums.
https://www.eurocarparts.com/p/redline- ... -993778201
Re: The Triumph
ChrisW wrote: Wed May 03, 2023 8:59 am Surfuctant. I just like the word.
Sounds like an Aussie beach dood.
Re: The Triumph
Washed and polished. MOT tomorrow morning at 10am.
Re: The Triumph
Passed MOT. Advisory on front tyre, so ordered in a Pilot Road 4 to be fitted next week. Local place, so will keep them in business. They may also be able to do the fork oil at the same time. Worth it for me.
