The Triumph
Has thanked: 2098 times
Been thanked: 2558 times
Re: The Triumph
Got the stud out of the extractor. Pipe vice grips. Sorted. Gave a weak attempt at one of the studs, but there is not much material to grab. I''ve sprayed them again and will try again later on or tomorrow. Only 4 studs to get out, and hopefully none of them snap....
Bought a butane torch to heat the studs up, maybe that will help. I'll even wear gloves (leather ones too). Guess I will have to drain that radiator now and get it off and I need more access to the engine.
Re: The Triumph
Fan and radiator off. Badly rusted fan shroud. May need to replace that.
Studs really are bad. I'll have to rewire the indicators as well. Tank off job for that as well. This is all mounting up to be a big job (not like it was ever a small job anyhow). So I may as well replace the throttle cables with new longer ones as well thanks to the bar risers.
Re: The Triumph
5 studs are now out. Just the one remaining that is resisting all efforts. It is starting to round off with the extractor I am using, so looks like I somehow need to get a nut welded on there. Problem is that the bike is in pieces and I really don't want to drop the engine to get the head off.
What suggestions? I've used a little blow torch (butane gas one) to head it and sprayed it with assorted lubricants/releasing agents. I've given it a tap with a hammer to loosen the thread. I've also rocked it tighter/looser and no movement.
So close!!
Been thanked: 15490 times
Re: The Triumph
the_priest wrote: Wed Apr 26, 2023 1:45 pm 5 studs are now out. Just the one remaining that is resisting all efforts. It is starting to round off with the extractor I am using, so looks like I somehow need to get a nut welded on there. Problem is that the bike is in pieces and I really don't want to drop the engine to get the head off.
So close!!
Oooooh good effort matey. I'm impressed.
What lubricants have you tried ? How hot did you get it ?
Ditchfinder
Has thanked: 861 times
Been thanked: 1069 times
Re: The Triumph
Post by Ditchfinder »
Can you get two nuts on it and lock them together?
Re: The Triumph
Re: The Triumph
They are pretty much corroded to bits.
Re: The Triumph
weeksy wrote: Wed Apr 26, 2023 1:47 pm
So close!!
Blaster Spray, Plusgas and a little Creme Brulee torch thingy. Extractor looks like a drill bit end that you wind onto the stud and then wind off. It has been very good on 5 of them! This stud is a bit to worn for it to grip properly.
Re: The Triumph
For £500 plus expenses...
Re: The Triumph
Victory is mine! Sacrificed a stud extractor and hammered it on, wound it out and job done!
Re: The Triumph
New studs with lots of copperslip and new copper exhaust gaskets to be put on at some point. Very pleased. Now I can also put on the connectors for the indicators and all will be ready for that MOT I need to book after re-insuring the bike.
Re: The Triumph
the_priest wrote: Wed Apr 26, 2023 2:26 pm New studs with lots of copperslip and new copper exhaust gaskets to be put on at some point. Very pleased. Now I can also put on the connectors for the indicators and all will be ready for that MOT I need to book after re-insuring the bike.
Now... about this cheap Triumph i'm buying off you :D
Re: The Triumph
weeksy wrote: Wed Apr 26, 2023 2:35 pm
Hhahahahahaha. I've just insured it from 1/5/23! £158 FC and I'm happy with that. So I'm looking forward to riding it again as it will be quieter (no more blowing exhaust!) Just need to sort indicators now. Have new connectors as well.
Pictures later on. I've got some Priest work to do now. But so pleased I got this finished.
Re: The Triumph
New connectors for indicators. Will solder them and heatshrink (already added). That is a job for another day. I've got two OEM indicators for rear of the bike. That will make a lovely difference.
Re: The Triumph
Need to do a bit of painting to protect the engine cases. I've got the right high temp paint, so that will be easy to sort. Used it on the BMW as well, good stuff it is.
Curry night is calling, so beer and food for me, Saturday I might get a chance to look at the bike again.
Re: The Triumph
Old exhaust gaskets. Yes that explains why it was blowing, nevermind that only two studs had nuts on them!
Re: The Triumph
The horrors that I started with!
Has thanked: 20858 times
Been thanked: 13676 times
Re: The Triumph
Amazing job mate! As the old saying goes, someone up there likes you! ;) :D
Has thanked: 12607 times
Been thanked: 8537 times
Re: The Triumph
Taipan wrote: Wed Apr 26, 2023 6:36 pm Amazing job mate! As the old saying goes, someone up there likes you! ;) :D
Friends in (very) high places ;)
A_morti
Has thanked: 412 times
Been thanked: 824 times
Re: The Triumph
Post by A_morti »
May be obvious, but get in to the gasket surfaces with a wire brush and get all the deposits away, so the new gaskets don't go the same as that old one.
