The Triumph
- the_priest
- Has thanked: 2098 times
- Been thanked: 2558 times
Re: The Triumph
Got the stud out of the extractor. Pipe vice grips. Sorted. Gave a weak attempt at one of the studs, but there is not much material to grab. I''ve sprayed them again and will try again later on or tomorrow. Only 4 studs to get out, and hopefully none of them snap....
Bought a butane torch to heat the studs up, maybe that will help. I'll even wear gloves (leather ones too). Guess I will have to drain that radiator now and get it off and I need more access to the engine.
- the_priest
Re: The Triumph
Fan and radiator off. Badly rusted fan shroud. May need to replace that.
Studs really are bad. I'll have to rewire the indicators as well. Tank off job for that as well. This is all mounting up to be a big job (not like it was ever a small job anyhow). So I may as well replace the throttle cables with new longer ones as well thanks to the bar risers.
- the_priest
Re: The Triumph
5 studs are now out. Just the one remaining that is resisting all efforts. It is starting to round off with the extractor I am using, so looks like I somehow need to get a nut welded on there. Problem is that the bike is in pieces and I really don't want to drop the engine to get the head off.
What suggestions? I've used a little blow torch (butane gas one) to head it and sprayed it with assorted lubricants/releasing agents. I've given it a tap with a hammer to loosen the thread. I've also rocked it tighter/looser and no movement.
So close!!
So close!!
- Has thanked: 6125 times
- Been thanked: 15493 times
Re: The Triumph
Oooooh good effort matey. I'm impressed.the_priest wrote: Wed Apr 26, 2023 1:45 pm 5 studs are now out. Just the one remaining that is resisting all efforts. It is starting to round off with the extractor I am using, so looks like I somehow need to get a nut welded on there. Problem is that the bike is in pieces and I really don't want to drop the engine to get the head off.
So close!!
What lubricants have you tried ? How hot did you get it ?
- Ditchfinder
- Has thanked: 861 times
- Been thanked: 1069 times
Re: The Triumph
Can you get two nuts on it and lock them together?
- the_priest
Re: The Triumph
- the_priest
Re: The Triumph
They are pretty much corroded to bits.
- the_priest
Re: The Triumph
Blaster Spray, Plusgas and a little Creme Brulee torch thingy. Extractor looks like a drill bit end that you wind onto the stud and then wind off. It has been very good on 5 of them! This stud is a bit to worn for it to grip properly.weeksy wrote: Wed Apr 26, 2023 1:47 pmOooooh good effort matey. I'm impressed.the_priest wrote: Wed Apr 26, 2023 1:45 pm 5 studs are now out. Just the one remaining that is resisting all efforts. It is starting to round off with the extractor I am using, so looks like I somehow need to get a nut welded on there. Problem is that the bike is in pieces and I really don't want to drop the engine to get the head off.
So close!!
- Been thanked: 9495 times
- the_priest
Re: The Triumph
Victory is mine! Sacrificed a stud extractor and hammered it on, wound it out and job done!
- the_priest
Re: The Triumph
New studs with lots of copperslip and new copper exhaust gaskets to be put on at some point. Very pleased. Now I can also put on the connectors for the indicators and all will be ready for that MOT I need to book after re-insuring the bike.
Re: The Triumph
Now... about this cheap Triumph i'm buying off youthe_priest wrote: Wed Apr 26, 2023 2:26 pm New studs with lots of copperslip and new copper exhaust gaskets to be put on at some point. Very pleased. Now I can also put on the connectors for the indicators and all will be ready for that MOT I need to book after re-insuring the bike.
- the_priest
Re: The Triumph
Hhahahahahaha. I've just insured it from 1/5/23! £158 FC and I'm happy with that. So I'm looking forward to riding it again as it will be quieter (no more blowing exhaust!) Just need to sort indicators now. Have new connectors as well.weeksy wrote: Wed Apr 26, 2023 2:35 pmNow... about this cheap Triumph i'm buying off youthe_priest wrote: Wed Apr 26, 2023 2:26 pm New studs with lots of copperslip and new copper exhaust gaskets to be put on at some point. Very pleased. Now I can also put on the connectors for the indicators and all will be ready for that MOT I need to book after re-insuring the bike.![]()
Pictures later on. I've got some Priest work to do now. But so pleased I got this finished.
- the_priest
Re: The Triumph
New connectors for indicators. Will solder them and heatshrink (already added). That is a job for another day. I've got two OEM indicators for rear of the bike. That will make a lovely difference.
- the_priest
Re: The Triumph
Need to do a bit of painting to protect the engine cases. I've got the right high temp paint, so that will be easy to sort. Used it on the BMW as well, good stuff it is.
Curry night is calling, so beer and food for me, Saturday I might get a chance to look at the bike again.
- the_priest
Re: The Triumph
Old exhaust gaskets. Yes that explains why it was blowing, nevermind that only two studs had nuts on them!
- the_priest
Re: The Triumph
The horrors that I started with!
- Has thanked: 20863 times
- Been thanked: 13684 times
- Has thanked: 12608 times
- Been thanked: 8539 times
Re: The Triumph
Friends in (very) high placesTaipan wrote: Wed Apr 26, 2023 6:36 pm Amazing job mate! As the old saying goes, someone up there likes you!![]()
