My knees are mechanical knees and I have no problems with them in most respects. I was walking c10 miles a day in NYC recently. The problem I have is just changing gear! Mechanical knees don't have quite the same movement as human ones, so whilst I can turn my toes in towards the gear lever, its the up and down movement of the in-turned foot that is causing my problems. It may be scar tissue from the operation or tendons etc? I really don't know, but where I thought I could push through it, it turns out I can't and the more I do the more it aches and the knee becomes slightly inflamed and tight to move. I'm a serenity prayer kind of guy and if that's the way it is, so be it, I'll just move on to something else, e.g. said autos.Skub wrote: Wed Jul 05, 2023 1:34 pm If you have dicky knees the last thing you need is some heavy 240kg + monstrosity of a bike. You'll probably pop a joint just pushing it around.
NBT: I've bought a Honda!
- Has thanked: 20859 times
- Been thanked: 13679 times
Re: NBT: I've bought a Honda!
Surprising really as the DCT has become a bit of a success story for Honda, but most other manufacturers are limiting themselves to CVT scoots?Dodgy69 wrote: Wed Jul 05, 2023 1:48 pm Doesn't seem to be much choice in auto's..
https://begin-motorcycling.co.uk/automatic-motorbikes/
Nah, McSatan has a Zero already. Also, its too much money for me to commute on and I'm still not sure about the range either?Ditchfinder wrote: Wed Jul 05, 2023 1:38 pm Will taipan be the first of us onto a leccy bike I wonder......
What if you made the actual toe part of the gear lever longer,so you didn't need to turn in your foot?Taipan wrote: Wed Jul 05, 2023 2:52 pmMy knees are mechanical knees and I have no problems with them in most respects. I was walking c10 miles a day in NYC recently. The problem I have is just changing gear! Mechanical knees don't have quite the same movement as human ones, so whilst I can turn my toes in towards the gear lever, its the up and down movement of the in-turned foot that is causing my problems. It may be scar tissue from the operation or tendons etc? I really don't know, but where I thought I could push through it, it turns out I can't and the more I do the more it aches and the knee becomes slightly inflamed and tight to move. I'm a serenity prayer kind of guy and if that's the way it is, so be it, I'll just move on to something else, e.g. said autos.Skub wrote: Wed Jul 05, 2023 1:34 pm If you have dicky knees the last thing you need is some heavy 240kg + monstrosity of a bike. You'll probably pop a joint just pushing it around.![]()
- Been thanked: 9495 times
Get a toe/heel shift lever like on a C90.
My little 110 Vox had one it was great for not messing your nice shoes up changing gear.
S'wat ive been doing. Was looking at the ID of my jack handle last night!Skub wrote: Wed Jul 05, 2023 3:02 pmWhat if you made the actual toe part of the gear lever longer,so you didn't need to turn in your foot?Taipan wrote: Wed Jul 05, 2023 2:52 pmMy knees are mechanical knees and I have no problems with them in most respects. I was walking c10 miles a day in NYC recently. The problem I have is just changing gear! Mechanical knees don't have quite the same movement as human ones, so whilst I can turn my toes in towards the gear lever, its the up and down movement of the in-turned foot that is causing my problems. It may be scar tissue from the operation or tendons etc? I really don't know, but where I thought I could push through it, it turns out I can't and the more I do the more it aches and the knee becomes slightly inflamed and tight to move. I'm a serenity prayer kind of guy and if that's the way it is, so be it, I'll just move on to something else, e.g. said autos.Skub wrote: Wed Jul 05, 2023 1:34 pm If you have dicky knees the last thing you need is some heavy 240kg + monstrosity of a bike. You'll probably pop a joint just pushing it around.![]()
- Has thanked: 12607 times
- Been thanked: 8537 times
Buy an old Indian with hand gear change
Dell Boy was always partial to a good Ruby
A_morti
- Has thanked: 412 times
- Been thanked: 824 times
https://www.ebay.co.uk/itm/185821114772
That and a small amount of time with a drill, plus a normal heim joint for the top of the linkage would see it done, and all completely reversible.
- Has thanked: 4088 times
- Been thanked: 2513 times
One of my mate's has a Yamaha Roadstar with Heel/Toe gear change.It's a big od bus so I'm not sure about filtering on the commute.KungFooBob wrote: Wed Jul 05, 2023 3:05 pm Get a toe/heel shift lever like on a C90.
https://www.motorcyclespecs.co.za/model ... r%2099.htm
Yup. That's deffo @TaipanBustaspoke wrote: Wed Jul 05, 2023 5:42 pmOne of my mate's has a Yamaha Roadstar with Heel/Toe gear change.It's a big od bus so I'm not sure about filtering on the commute.KungFooBob wrote: Wed Jul 05, 2023 3:05 pm Get a toe/heel shift lever like on a C90.
Well the heavy bar end weights turned up. I should have weighed them all, but they feel at lest twice as heavy as the R&G ones! Be interesting to see if the help out at all...
R&G sell some proper tat. Some folk are obsessed with them, same as Renthall'sTaipan wrote: Wed Jul 05, 2023 7:34 pm Well the heavy bar end weights turned up. I should have weighed them all, but they feel at lest twice as heavy as the R&G ones!
- Has thanked: 2852 times
- Been thanked: 3505 times
You know what.. I'd be tempted to look at that Rebel 1100.
Busy roads, stop/start . It'll have a low seat, go/stop well enough, luggage options. The adventure alternative.
Test ride time.
Test ride time.
I also thought it looedk right up Tiepins alley, however I suspect having been a Hardly owner the idea of riding a plastic Nippon copy might put him off.Dodgy69 wrote: Thu Jul 06, 2023 8:43 am You know what.. I'd be tempted to look at that Rebel 1100.Busy roads, stop/start . It'll have a low seat, go/stop well enough, luggage options. The adventure alternative.
Test ride time.![]()
Tbh, I'd have a test ride myself...Talking to a mate last night, he just picked up a Triumph America, bit tatty but he loves it for plodding around in comfort . It's got those forward pegs. I sat on it and foot position is absolutely foreign to me, but he says you quickly adapt and it's mega comfy.
Phrase of the day...Rule nothing out.
I forgot about the Triumph Speedmaster i had (same/similar to America)! It was good, but very long iirc, so not such a great commuter? I wonder what the Rebel is like?Dodgy69 wrote: Thu Jul 06, 2023 8:54 am Tbh, I'd have a test ride myself...Talking to a mate last night, he just picked up a Triumph America, bit tatty but he loves it for plodding around in comfort . It's got those forward pegs. I sat on it and foot position is absolutely foreign to me, but he says you quickly adapt and it's mega comfy.
Phrase of the day...Rule nothing out.![]()
1100 Rebel DCT is £10499 OTR! Just watched Chaseonwowheels (American youtuber) review one. He says what I thought when I saw him on it, your feet are too far back. It needs forward controls. He does say it goes round corners though. I think I'd favour the AT DCT over one tbh.
Just watched and I think it's ace for today's roads. Don't think pegs were a massive issue. Harder seats are usually fine . CC on the rhs isn't a problem either. Nice low seat, enough power and I like the kind of bagger look with the fairing thing. Didn't say how big the tank was. ?
Personally I'd have this over the AT. The adventure look is done and this look is where it's at. I'd have one tomorrow.
A_morti
The fuel tank capacity of Rebel 1100 is 13.6 L.
That's silly, and might be an issue for TiePin.
Depends how frugal it is, I guess.
