Is that similar to the Kev mod used on the xt660 range, sits in series with the airbox temp sensor and fools the ECU into reading air temp lower and riches up the fuel air mix ?Taipan wrote: Thu Mar 30, 2023 12:58 pm Fitted the AFM controller today. No real elegant way to fit it really. Some people hide them in the headlight cowl, which I may eventually do, but I want to be able to adjust as I nee to first. Just waiting on DPD with my Remus now!
NBT: Sexy red beast has been bought and heading my way!
Gregor
- Has thanked: 1758 times
- Been thanked: 1153 times
Re: NBT: Sexy red beast has been bought and heading my way!
- Has thanked: 20881 times
- Been thanked: 13701 times
Exaactly that! Booster plug is the same thing but with no adjustability. Apparently these work really well, even on bikes running full piggy back controllers and some remaps as the help with the (dire) closed loop.Gregor wrote: Thu Mar 30, 2023 1:09 pmIs that similar to the Kev mod used on the xt660 range, sits in series with the airbox temp sensor and fools the ECU into reading air temp lower and riches up the fuel air mix ?Taipan wrote: Thu Mar 30, 2023 12:58 pm Fitted the AFM controller today. No real elegant way to fit it really. Some people hide them in the headlight cowl, which I may eventually do, but I want to be able to adjust as I nee to first. Just waiting on DPD with my Remus now!
Could you not get some carbon look cable ties,at least?
- ChrisW
- Has thanked: 3714 times
- Been thanked: 3027 times
Or maybe....?
- italzip.png (62.28 KiB) Viewed 477 times
I think "controller" might be over selling it a bit. It's just a variable resistor right?
The electronic version of a woman?Mr. Dazzle wrote: Thu Mar 30, 2023 1:53 pm I think "controller" might be over selling it a bit. It's just a variable resistor right?![]()
We prefer electro mechanical transducer if you don't mind!Mr. Dazzle wrote: Thu Mar 30, 2023 1:53 pm I think "controller" might be over selling it a bit. It's just a variable resistor right?![]()
Pleased with that! Look forward to test riding it tomorrow! I didn’t come with the catalytic push in thing, so maybe too loud? Doesn’t sound too bad just blipping the throttle but it’s always different when riding them!
[url=https://ibb.co/vwzPLDc]
- ChrisW
That really does look nice, lucky the other one didn't work out
- Has thanked: 2857 times
- Been thanked: 3514 times
Do you have to adjust the advance and retard on the fly while in a certain rev range.
- MyLittleStudPony
- Has thanked: 832 times
- Been thanked: 586 times
[retches uncontrollably]Taipan wrote: Thu Mar 30, 2023 12:58 pm Fitted the AFM controller today. No real elegant way to fit it really. Some people hide them in the headlight cowl, which I may eventually do, but I want to be able to adjust as I nee to first. Just waiting on DPD with my Remus now!
Get it hidden in the headlight cowl. Or anywhere!
I went to a meet up of Hypers earlier. About 30 or so there.MyLittleStudPony wrote: Thu Mar 30, 2023 6:22 pm[retches uncontrollably]Taipan wrote: Thu Mar 30, 2023 12:58 pm Fitted the AFM controller today. No real elegant way to fit it really. Some people hide them in the headlight cowl, which I may eventually do, but I want to be able to adjust as I nee to first. Just waiting on DPD with my Remus now!
Someone said, "Who's that on the sweet red 939"?
Someone replied, "Thats Taipan and he has a frame mounted SC Project AFM controller"!
The original guy said, "Wow, what a guy"!
- Has thanked: 5969 times
- Been thanked: 3573 times
You fucker! I wouldn't even do that to my grown up Bandit. Poor thing.Taipan wrote: Thu Mar 30, 2023 12:58 pm Fitted the AFM controller today. No real elegant way to fit it really. Some people hide them in the headlight cowl, which I may eventually do, but I want to be able to adjust as I nee to first. Just waiting on DPD with my Remus now!
I need to be able to adjust it and don't want to start removing panels each time. Once its set up, I'm pretty sure the cable is long enough to get it under the seat!Supermofo wrote: Thu Mar 30, 2023 7:21 pmYou fucker! I wouldn't even do that to my grown up Bandit. Poor thing.Taipan wrote: Thu Mar 30, 2023 12:58 pm Fitted the AFM controller today. No real elegant way to fit it really. Some people hide them in the headlight cowl, which I may eventually do, but I want to be able to adjust as I nee to first. Just waiting on DPD with my Remus now!
- ChrisW
If the cable's long is there any way you could get it on the handlebars? Be able to see the dial too.
I was thinking it'd look (a little) less gash on the barsChrisW wrote: Thu Mar 30, 2023 7:33 pm If the cable's long is there any way you could get it on the handlebars? Be able to see the dial too.
- Been thanked: 9497 times
Looking like a low rent heated grips controller.
- ChrisW
It's better looking than an oxford grips controller...
Marginally.ChrisW wrote: Thu Mar 30, 2023 8:01 pmIt's better looking than an oxford grips controller...
