The 10+ year KX500 rebuild thread
lostboy
Has thanked: 2152 times
Been thanked: 426 times
Re: The 10+ year KX500 rebuild thread
Post by lostboy »
I can't be the only one that is assuming that every time there's a post on here it will be of you in shorts and flip flops, helmetless, tearing up and down your road pissing off the neighbours with a cloud of two stroke gases!
Top work.
derek badger
Has thanked: 1091 times
Been thanked: 1753 times
Post by derek badger »
lostboy wrote: Fri Jul 30, 2021 8:15 am I can't be the only one that is assuming that every time there's a post on here it will be of you in shorts and flip flops, helmetless, tearing up and down your road pissing off the neighbours with a cloud of two stroke gases!
Top work.
It stops being a project if you finish it...
Just making a mount for a CRF sidestand then I'll be concentrating on finishing the rollers. Need to MOT the little CG125 also, but that can wait.
3 kids under 9yrs mean there is always something that needs fixing round the house, and with the schools out the wife and I have no spare time for much else besides stopping them killing each other at the minute.
Bigyin
Has thanked: 1436 times
Been thanked: 2738 times
Post by Bigyin »
Top work.
How long exactly have you known the Badger ;)
The day that happens the sound of Boris bullshit will be drowned out by the clang of all the jaws dropping that its actually finished :mrgreen:
Has thanked: 20876 times
Been thanked: 13695 times
In case you wanted a bit of inspiration...
Liamblack1987
Has thanked: 1 time
Post by Liamblack1987 »
derek badger wrote: Sat Jan 09, 2021 11:55 am Result.
The statement that says it was originally supplied in the UK should mean I don't need to go through the NOVA stuff as it's not been imported.
Hi Derek
I have the same letter from kawasaki with a kx I have just purchased. Have you applied for logbook yet? Did you have to contact the nova registration or did you just do mot and full the v55/5
Thanks Liam
Has thanked: 8045 times
Been thanked: 5696 times
Liamblack1987 wrote: Sun Jan 29, 2023 7:52 pm
Hi Derek
Thanks Liam
He's a bit elusive is Mr Badger, worth tagging @derek badger to see if he's still communicado. :thumbup:
Liamblack1987
Has thanked: 1 time
@derek badger
Liamblack1987 wrote: Sun Jan 29, 2023 8:06 pm @derek badger
He'll have 2 pings now. If he responds we can ask him how his motorised roller bump start machine is coming along. :thumbup:
Been thanked: 9496 times
Count Steer wrote: Sun Jan 29, 2023 8:11 pm
I imagine he's not on here very often because he's been killed by those rollers.
He's on FB,I've given him a shout.
derek badger
Dating letters only last 12 months, I've been advised to do Nova route and send it and a letter stating I bought it as a Box of bits at an Autojumble to avoid the chance of getting charged import duty.
I registered a YZ465 years ago and it was pretty easy. MOT on frame number then apply for V5 with supporting paperwork. Didn't have a NOVA certificate for that one.
Might be worth pinging @Liamblack1987 that there's been a reply. :)
:thumbup:
derek badger
Starter rollers are done. As someone told me, "Well done. You've managed to make an angle grinder more dangerous..."
derek badger wrote: Fri May 30, 2025 9:58 pm Starter rollers are done. As someone told me, "Well done. You've managed to make an angle grinder more dangerous..."
Needs the foot pedal off an old sewing machine as a control.
Ian
Has thanked: 1361 times
Been thanked: 578 times
Post by Ian »
Has it got enough torque to start the KX?
Has thanked: 1059 times
Been thanked: 1646 times
Ian wrote: Thu Jun 05, 2025 11:00 pm Has it got enough torque to start the KX?
I've seen some of these grinder starters at Barbon Hillclimb starting big singles, can't remember if they did CR50s or KX500s but could likely look through old photos to find out.
They'll have been 9" grinders which are pretty ferkin evil themselves.
derek badger
demographic wrote: Fri Jun 06, 2025 1:28 pm
This is a 9" model :thumbup:
Would this work for spinning over your KX?
A boot up the badger's arse may also help. :lol:
