Fold flat front passenger seat FTW!
Felix wrote: Fri Apr 29, 2022 4:50 pmIs that Belfast?
Yep. Sydenham Road,just beside Harland & Wolf shipyard.
Has thanked: 714 times
Been thanked: 2039 times
Skub wrote: Sat Apr 30, 2022 8:24 pm
It was funny as i was nit long reading that the Chinese were making a full scale version of the Titanic and was that not the spot the original was made? Just spooky you posted it and why i asked were Harland & Wolf not on the Clyde also?
Felix wrote: Sat Apr 30, 2022 9:48 pm
Apparently they had a small yard in Govan which closed in 63. I didn't know that.
That will explain why i was not to sure. I was born in 63 :lol:
Me, bruv and nephew. And random burds...
I came across this today.
A bloke uses this block of lead for retrieving small gear off the side of his boat. It used to be square edged until he left it on his porch in Florida and the squirrels developed a taste for lead. :shock:
inewham wrote: Mon May 02, 2022 5:55 pm ISTR the Romans used lead as a sweetener so I guess it must taste good :shock:
Every day's a school day.
Has thanked: 1080 times
Been thanked: 1010 times
Post by slowsider »
Has thanked: 7620 times
According to several posts on here, many small rodents receive their lead by injection, at high speed, in pellet form ;)
Felix wrote: Fri Apr 29, 2022 4:51 pm Image
Day after i bought that pump ^^^ i found out a mechanical pump would have fitted straight in. One from a Landrover 300tdi. Just set the timing 180 degree out. Add a mechanical throttle and cable and you can bin the ECU. No more EML or immobiliser just disconnect the ECU and tuck the wires away. Throttle also.
Why was i not told before hand :(
Worth looking into you Mk6 Transit owners :thumbup:
Don't the engines with mechanical pumps usually have different injectors to the ECU ones?
On the good 'ole Rover L-Series, you could fit the injectors from the mechanical pump engine to the ECU pump engine for an instant 20bhp boost.
Different break pressures and spray patterns.
KungFooBob wrote: Mon May 02, 2022 9:24 pm Don't the engines with mechanical pumps usually have different injectors to the ECU ones?
Apparently you leave the originals in. The Mk6 are not codded like the 7. Apparently the Turks have been doing it for years with a VE Pump??
https://www.google.co.uk/search?q=trans ... ent=safari
Here is a guy who kind of made a VE pump with bits. He has a few other video if you do a search
Been thanked: 13675 times
Yorick wrote: Sun May 01, 2022 9:30 pm Me, bruv and nephew. And random burds...
Great photo! Seriously, that is a great photo! :thumbup:
Taipan wrote: Mon May 02, 2022 11:32 pm
3 Bradford lads means it has to be good :obscene-birdiedoublered:
Has thanked: 2098 times
Been thanked: 2558 times
Having a buzzing time!
Davie lad
Has thanked: 193 times
Been thanked: 238 times
Post by Davie lad »
Heasta, Isle of Skye, over looking Broadford
Oh i can see my old Neighbours hoose. Hi Irene :wave:
