Posts: 17501 Joined: Sat Mar 14, 2020 1:04 pm
Has thanked: 627 times
Been thanked: 9495 times
Post
by KungFooBob » Sat Apr 30, 2022 5:46 pm
Fold flat front passenger seat FTW!
Posts: 14892 Joined: Mon Mar 16, 2020 5:32 pm
Has thanked: 13109 times
Been thanked: 14170 times
Post
by Skub » Sat Apr 30, 2022 8:24 pm
Felix wrote: Fri Apr 29, 2022 4:50 pm Is that Belfast?
Yep. Sydenham Road,just beside Harland & Wolf shipyard.
Posts: 5238 Joined: Sat Jul 17, 2021 12:34 am
Has thanked: 714 times
Been thanked: 2039 times
Post
by Felix » Sat Apr 30, 2022 9:48 pm
Skub wrote: Sat Apr 30, 2022 8:24 pm
It was funny as i was nit long reading that the Chinese were making a full scale version of the Titanic and was that not the spot the original was made? Just spooky you posted it and why i asked were Harland & Wolf not on the Clyde also?
Post
by Skub » Sat Apr 30, 2022 9:57 pm
Felix wrote: Sat Apr 30, 2022 9:48 pm
Apparently they had a small yard in Govan which closed in 63. I didn't know that.
Post
by Felix » Sat Apr 30, 2022 10:54 pm
That will explain why i was not to sure. I was born in 63
Posts: 19927 Joined: Sat Mar 14, 2020 8:20 pm
Has thanked: 12606 times
Been thanked: 8536 times
Post
by Yorick » Sun May 01, 2022 9:30 pm
Me, bruv and nephew. And random burds...
Post
by Skub » Mon May 02, 2022 5:16 pm
I came across this today.
A bloke uses this block of lead for retrieving small gear off the side of his boat. It used to be square edged until he left it on his porch in Florida and the squirrels developed a taste for lead.
Post
by Skub » Mon May 02, 2022 6:13 pm
inewham wrote: Mon May 02, 2022 5:55 pm
ISTR the Romans used lead as a sweetener so I guess it must taste good
Every day's a school day.
Posts: 14228 Joined: Sun Mar 15, 2020 11:30 am
Has thanked: 7620 times
Been thanked: 5929 times
Post
by Horse » Mon May 02, 2022 6:45 pm
According to several posts on here, many small rodents receive their lead by injection, at high speed, in pellet form
Post
by Felix » Mon May 02, 2022 9:21 pm
Felix wrote: Fri Apr 29, 2022 4:51 pm
Day after i bought that pump ^^^ i found out a mechanical pump would have fitted straight in. One from a Landrover 300tdi. Just set the timing 180 degree out. Add a mechanical throttle and cable and you can bin the ECU. No more EML or immobiliser just disconnect the ECU and tuck the wires away. Throttle also.
Why was i not told before hand
Worth looking into you Mk6 Transit owners
Post
by KungFooBob » Mon May 02, 2022 9:24 pm
Don't the engines with mechanical pumps usually have different injectors to the ECU ones?
On the good 'ole Rover L-Series, you could fit the injectors from the mechanical pump engine to the ECU pump engine for an instant 20bhp boost.
Different break pressures and spray patterns.
Post
by Felix » Mon May 02, 2022 9:40 pm
KungFooBob wrote: Mon May 02, 2022 9:24 pm
Apparently you leave the originals in. The Mk6 are not codded like the 7. Apparently the Turks have been doing it for years with a VE Pump??
https://www.google.co.uk/search?q=trans ... ent=safari
Here is a guy who kind of made a VE pump with bits. He has a few other video if you do a search
Posts: 19330 Joined: Sat Mar 14, 2020 1:48 pm
Has thanked: 20857 times
Been thanked: 13675 times
Post
by Taipan » Mon May 02, 2022 11:32 pm
Yorick wrote: Sun May 01, 2022 9:30 pm
Great photo! Seriously, that is a great photo!
NC750X mpg
Post
by Yorick » Mon May 02, 2022 11:35 pm
Taipan wrote: Mon May 02, 2022 11:32 pm
3 Bradford lads means it has to be good
Posts: 2261 Joined: Sun Mar 15, 2020 2:18 pm
Has thanked: 2098 times
Been thanked: 2558 times
Post
by the_priest » Tue May 03, 2022 9:24 am
Having a buzzing time!
Davie lad
Posts: 165 Joined: Mon Mar 16, 2020 3:44 pm
Has thanked: 193 times
Been thanked: 238 times
Post
by Davie lad » Tue May 03, 2022 6:03 pm
Heasta, Isle of Skye, over looking Broadford
Post
by Felix » Tue May 03, 2022 6:20 pm
Oh i can see my old Neighbours hoose. Hi Irene
