NBT: Sexy red beast has been bought and heading my way!
Has thanked: 5969 times
Been thanked: 3573 times
Re: NBT: Sexy red beast has been bought and heading my way!
Le_Fromage_Grande wrote: Mon Mar 27, 2023 4:42 pm
Supermofo wrote: Mon Mar 27, 2023 4:35 pm What you want is a nice GSXS 1000. Pick a gear, any gear will work at about 20mph and it trickles along nicely. It does have an iffy fueling spot but much higher up the rev range but it's perfect in traffic
There's no iffy fueling on the 750, but then again I don't trickle along at low rpm in high gears, or go out of my way to find bad fuelling, I also owned a Husky 610 with a Dell Horrible carb, which fuelled worse than a poorly tuned two stroke, so what I consider good might be what Taipan considers bad.
Wouldn't say iffy as such l, but very very sensitive at about 7-8k rpm. OK on or off the throttle completely but trying to be sensitive and its cuts in/out. I ride round it most of the time, but it's there
Has thanked: 20883 times
Been thanked: 13701 times
Like I say, for a fair chunk of my commute, I'm at part throttle, 2-4k ish revs which is where most modern Fi bikes play up, so I notice it more than most.would obvs! I thoroughly enjoyed Saturdays ride out on the Essex peninsular, but it was a marked contrast to today's commute. Its no biggie though as I already knew it'd be like this and have had a bike remapped, like many others, I know what massive difference that can make and look forward to getting it done. The point of mentioning these things is I don't like to gloss over things that are apparent with any model of bike I own. It can be misleading to prospective buyers of the same model.
Anyway, enough of that, the bike was superb in batting through the traffic on the way home. IIRC someone said it was heavy, but ti doesn't feel it.The opposite in fact, its very flickable! Sadly the exhaust had to be removed. The angle was all wrong, which i'd have seen if I hadn't legged it indoors when the heavens opened yesterday. I checked the SC project website and sure enough, there is a hanger bracket that I didn't get. I connected the seller who hasn't got the hanger but apologised and offered full refund etc.
I connected SC Project who replied straight back! Yes they will sell me the hanger bracket and ist a lot cheaper than sy a R&G one (see below). I'm hoping the seller will refund me that amount rather than take the exhaust back, as that would work better for both of us. We'll see what he says tomorrow.
Seller paying for the new hanger bracket. Proper chuffed about that, as its the can I wanted and saves me a good few quid over a new one. :thumbup: Dunno how long it'll take to get here from Italy though. Probably sold the bike by then! :silent: :think:
Has thanked: 1926 times
Been thanked: 1728 times
Le_Fromage_Grande wrote: Mon Mar 27, 2023 11:29 am Stop riding like a poof and thrash the tits out of it
I did kind of mention this on page one. Stop trying to ride it like a Harley
Has thanked: 7630 times
Been thanked: 5936 times
Taipan wrote: Mon Mar 27, 2023 8:08 pm Like I say, for a fair chunk of my commute, I'm at part throttle, 2-4k ish revs which is where most modern Fi bikes play up, so I notice it more than most.would obvs!
No offence, TP (and it probably applies to many others too), but the 'fuelling issues' are likely to be because of two things:
1. FI systems, switching off fuel to the motor on a closed throttle
2. Owners having a rip-snorting huge bhp engine, then not riding it in a way that uses the high power part of the rev range
Probably an indictment of owners more than bikes ;)
Horse wrote: Tue Mar 28, 2023 7:52 am
None taken. To repeat myself again,I commute through heavy traffic where you simply cannot use the higher rev range. You cannot ride around the problem. Changing the manufacturer's fuelling is the only option, or put up with it, which i'd rather not do.
I find it kinda strange that people will swap makes of performance tyres as they cant ride on one make over another, or change suspension etc, yet put up with shit fuelling that can be fixed? But then many years ago I was talking with legendary tuner, Stan Stephens. He was telling me about hosting dyno days for groups of people, where they'd come in and all get a dyno run for a pissing contest. He said so many would say they'd fitted a dynojet kit and now the bike had a massive top end rush. The reality was the bike was just climbing out of the massive hole in the midrange they'd just dialled in by incorrectly fitting a DJ kit. So I guess some people just don't notice bad fuelling, or care about it?
Has thanked: 4088 times
Taipan wrote: Tue Mar 28, 2023 8:47 am
I've not tried one yet,but I'm thinking about getting a Guzzi V7 Classic with the 850 motor & reading reviews & watching stuff on YT, people say that the motor's tuned for low down torque & it's all about the 'bottom end'.Not sure if the seating position would suit you but it could be worth a demo ride at some point.
Been thanked: 1610 times
IMHO, is it worth trying a carb'd bike as reckon that may suit your riding better but then I guess cause you issues with ULEZ?
EDIT: Looks like there are carb'd bikes that are ULEZ compliant
Go down 2 teeth on the front and up 7 on the back. Job jobbed. :thumbup:
Buckaroo
Has thanked: 1048 times
Been thanked: 1108 times
Post by Buckaroo »
Bustaspoke wrote: Tue Mar 28, 2023 9:08 am
I have to say that my v7 850 runs very well and is predictable. The low down torque that kicks in around 3000 rpm or so makes for a flexible engine in most gears. Position is slightly forward as opposed to sitting upright. I'm biased, but would recommend a demo ride.
v8-powered wrote: Tue Mar 28, 2023 9:22 am IMHO, is it worth trying a carb'd bike as reckon that may suit your riding better but then I guess cause you issues with ULEZ?
WTF There's a 1984 RD350 on that Ulez list!
I never thought there would be a Ulez compliant Old School 2 stroke :D
Bustaspoke wrote: Tue Mar 28, 2023 9:08 am a Guzzi V7 Classic with the 850 motor & reading reviews & watching stuff on YT, people say that the motor's tuned for low down torque & it's all about the 'bottom end'.
That's why the old K100 BMW was so easy to ride, torque 'curve'? Hardly!
Since I dropped my allegiance toJap bikes, a Guzzi has been on my radar for while now. It might well be the next bike?
Well it turns out SC Project wont sell me the bracket after all, so the can is being returned. :(
On the plus side one of these is winging its way to me as we speak! :thumbup:
Been thanked: 9499 times
Remus pipes are quality.
KungFooBob wrote: Tue Mar 28, 2023 11:04 am Remus pipes are quality.
Ja, sie sind. Deutsche Ingenieurskunst vom Feinsten. :thumbup:
It'd probably be worth trying out at least. Bt for now I'm super pleased with the Ducati, so I'll see April out before looking at anything else! :hmmm: :lol:
Has thanked: 19603 times
Been thanked: 4958 times
Similar to the people that shell out shitloads of money on 'lightweight' wheels, cans, frame etc etc etc and yet they are 6 stone overweight! There was never any point me buying weight saving stuff for the bike as I had a bit to lose first :lol: :lol: :lol:
Taipan wrote: Tue Mar 28, 2023 8:47 am I find it kinda strange that people will swap makes of performance tyres as they cant ride on one make over another, or change suspension etc, yet put up with shit fuelling that can be fixed?
My priorities with a new bike are,in order and if needed....
Suspension always comes first.
Brakes second.
Ergonomics 3rd.
Only after that will I resort to engine tweaking.
My requirements are also a lot different from yours Terrapin,I don't commute and I avoid riding in traffic as much as I possibly can.
Skub wrote: Tue Mar 28, 2023 5:14 pm
Brakes second.
Ergonomics 3rd.
What about when you're riding in town looking at yourself in shop windows? Or is that just me? :think:
:D
