Page 2 of 2
Re: Removing locking wheels nuts without the key
Posted: Wed Feb 14, 2024 9:17 am
by roadster
I had this problem with a second hand Nissan Note shortly after buying it. Ordered new nuts from a Nissan dealer and took it to them for the locking nuts to be removed. It didn't take them more than about ten minutes and I got the cost back from the seller who had lost the adapter. It did give the lie to the seller's claim that they carried out a full service before the sale!
Posted: Sat Feb 17, 2024 1:01 am
by Mussels
Horse wrote: Tue Feb 13, 2024 2:29 pm
mangocrazy wrote: Tue Feb 13, 2024 2:01 pm Is ali wheel theft still a problem these days? I thought the scrotes had moved on to nicking more lucrative parts years ago.
There was a post on LinkedIn that someones sporty BMW was written off after its steering wheel was stolen!
https://forums.m3cutters.co.uk/threads/ ... A6.266767/
Apparently a common theft:
https://www.kent.police.uk/news/kent/la ... e%20window.
I bought my Transit Custom just after they came out and the complete lack of spare panels meant nearly new vans were being written off for fairly minor side damage. A few people were left gobsmacked by that one.
Posted: Wed Feb 21, 2024 9:44 pm
by Scootabout
Had the problem with a Passat a few years ago. The now-independent-ex-VW-mechanic I was using for servicing had gone on holiday and left his assistant to do a job involving wheel removal. He attempted to remove the nut by force and failed. When his boss returned he called in a favour from the VW main dealer, to which I drove the car and had it sorted in ten minutes.
Posted: Wed Feb 21, 2024 9:58 pm
by Silly Car
Local back street garage would have the locking nuts / studs out of all four wheels in less than an hour’s labour. Most common method is to weld a hex nut onto the offending item and just undo it.
Or if not made from steel, hammer, punches and a sharp cold chisel, doesn’t take much longer than the welding trick with the car up in the air, PITA if you are scrabbling around on the floor
