SBH Stuff...
Been thanked: 7536 times
Re: SBH Stuff...
The first person in human history that an easy-out worked for?
Has thanked: 1508 times
Been thanked: 1415 times
Re: SBH Stuff...
KungFooBob wrote: Wed May 29, 2024 9:53 pm The first person in human history that an easy-out worked for?
These things are the dogs bollocks, they've worked every time I've used them:
It was the screw heads that were stuck, not the threads. I drilled the heads off then then went to drill a hole in the shank. They both turned in the holes, but there wasn't enough room on the back for the pieces to come through & fall out. They were already loose before I drilled for the doodads, spun right out.
Has thanked: 1829 times
Been thanked: 1469 times
Re: SBH Stuff...
Can I just ask “why?”
Re: SBH Stuff...
Mr Moofo wrote: Wed May 29, 2024 11:26 pm Can I just ask “why?”
Why what?
Re: SBH Stuff...
In today's "No good deed..." dept...
Yesterday I drilled out two unnecessary screws on the right/front brake assembly while swapping out the rotors & pads.
Got it back together & went for a test drive... during which I dropped by the dealer for two new screws, because OCD.
This morning I pop the wheel off to fit the screws.. and one of the frigging studs snapped. BUGGERY BOLLOCKS! Oddly it came off half way & then just fell into my hand as I was turning it.
So tightened the other 4 & drove to the dealer for a new lug & stud, because I don't want some Dorman stud made from play-doh.
And I discovered you can't just knock out the stud & press in the new one.. you have to knock it half way out & then cut it in half with the die grinder owing to clearance... (unless you remove & disassemble the hub)
Then you have to put a flat on one side of the new one to get it in.. FFS.
All done & dusted now.
Has thanked: 6381 times
Been thanked: 4762 times
Re: SBH Stuff...
ZRX61 wrote: Wed May 29, 2024 11:39 pm
Why what?
More like 'why not?'
(As in 'why not scrap it and get something that isn't quite such a drain on time/effort/$$s? It sounds like you don't like the car very much anyway).
Re: SBH Stuff...
I like Bangernomics. But the cost to do all of this seems to far outweigh the value of the car
Has thanked: 7820 times
Been thanked: 2530 times
Re: SBH Stuff...
Mr Moofo wrote: Fri May 31, 2024 7:48 am I like Bangernomics. But the cost to do all of this seems to far outweigh the value of the car
Sometimes it's simpler to spend XXX on the car and keep it going, it's a known-entity, than to spend the same (or a bit more) on swapping to an unknown entity.
Re: SBH Stuff...
Rockburner wrote: Fri May 31, 2024 11:01 am
There is always a point to stop
Re: SBH Stuff...
Mr Moofo wrote: Fri May 31, 2024 1:10 pm
I don't disagree. :)
I once had an E21 BMW 316, it cost me £600 to buy. (First car I bought with my own money :D )
Ran it for a couple of years and really liked it, but then it failed an MOT on rusty sills.
I was quoted £600 to repair it... so my father persuaded me to scrap it (I got £20 :( ), and buy a frigging VW Beetle for over twice that money.
The Beetle was such a disaster I don't even have a photo of it. I threw it back at them after 2 weeks and got most of my money back.
If I'd kept the BMW it probably would have lasted several more years - there was nothing else wrong with it.
Hell, I'd have one now.
First car and bike which I bought with my own money. :D (instead of running family vehicles).
Re: SBH Stuff...
I paid $1 for the SBH, the car is worth around $4000.
Seat covers: $109.14
Tires: $400 (iirc)
Shocks: $279.95
Brakes: $126.73
Headlights: $88.19
Air filter: 14.53
Total: $1018.55
I'm into this car for less than half the value of it, I could sell it tomorrow & easily make $2500 on the deal.
Edit: plus $12 for an OEM stud & lug nut
Re: SBH Stuff...
ZRX61 wrote: Fri May 31, 2024 3:20 pm
Tires: $400 (iirc)
Shocks: $279.95
Brakes: $126.73
Headlights: $88.19
Air filter: 14.53
Total: $1018.55
Do the wolves like it?
Re: SBH Stuff...
Mr Moofo wrote: Fri May 31, 2024 3:46 pm Do the wolves like it?
They were born April 6th '96, that would make them 28yo if they were still with us.
Has thanked: 485 times
Been thanked: 1428 times
Re: SBH Stuff...
I would have chucked the screw. Wheel nuts hold it all together anyway.
Has thanked: 15964 times
Been thanked: 10249 times
Re: SBH Stuff...
ZRX61 wrote: Wed May 29, 2024 11:02 pm
I've got some of those and had some success with them. These are also brilliant, the harder you turn they more they cut in. I had a sh300 and when i went to do a belt change I found it the crank nut was rounded off. One of these saved the day!
Re: SBH Stuff...
Got some of those too (different brand, RocketSockets) & some meaty internal ones (Irwin).
