Good choice on the S&S pipes. Their products are made by people who ride obsessively and make sure they work. I used to recommend S&S stuff to my clients. A bit more expensive, but you get what you pay for.
vance and hines are another company that makes aftermarket cruiser pipes that work. i have a V&H pro-pipe on the lardmobile and it works just as i wanted with the configuration i have.
the V&H bigshots and shortshots are pretty good pipes. the bigshots (can´t remember if the shortshots do) have a connecting chamber between the silencers for a bit of extra scavenging and work well. fit and finish is always good, and i´ve never had any problems mounting any V&H system.
the only potential downside is the shots are quite loud. you could probably add some extra packing material and /or a baffle plate to keep it down for long trips (where the noise can be tiring), or just exercise a bit of right hand restraint.
they´re not as loud as a lot of other pipes of similar looking types - exhaust noise is quite subjective - but they do have a nice tone to them.
i used to do a `wakeup´ kit for sportsters consisting of a replacement K&N filter, dynojet kit, and a set of khrome wers slip-ons for a very reasonable price, and had quite a few people coming to get them. the engine note on their slip-ons was always very deep and mellow. lovely sounding pipes!
Short shots are loud. Trouble is loud often means power loss if my experience of other big twins is anything to go by. The improved scavenging of linked long shots makes a lot of sense.
erizo wrote: Sat Apr 11, 2020 9:12 pm
Looking good!
You have to get creative with a bike that has no fairing or cubby holes, so a wee bit of sticky backed velcro later and a hidey hole for the DVR was found;
Sat Nav should help then. Must admit I often use my sat nav as a speedo as I only need to look in 1 place for current limit, my speed and where the hell I'm going!
First bimble out of the year
And I reckon the new sat nav is knackered it was only a quick 90 minute shake down ride to blow the dust off but it reckons I hit triple digit speeds
MrLongbeard wrote: Sun May 30, 2021 5:59 pm
