Tumble drier vent
mel
Has thanked: 13 times
Been thanked: 36 times
Re: Tumble drier vent
Post by mel »
demographic wrote: Sat Dec 31, 2022 9:40 pm Oh and don't use it on hammer, I'm surprised nobodys mentioned it yet.
Oh do keep up pls
Yeah, diamond core drill....do not use hammer action. Patience is a virtue. Unfortunately Skubs is in Norn Iron otherwise he could borrow all my 'used once' stuff. :thumbup:
These users thanked the author Count Steer for the post:
Has thanked: 1349 times
Been thanked: 1723 times
mel wrote: Sat Dec 31, 2022 10:11 pm
Oh do keep up pls
Err... oh... nevermind.
Has thanked: 6381 times
Been thanked: 4761 times
demographic wrote: Sat Dec 31, 2022 11:17 pm
Oh do keep up pls
:lol:
On the bright side this would normally have evolved into a ding dong argument where a qualified fish fryer with an 'O' Level in macramé absolutely insisted that hammer action must be used, much to the discombobulation of members of the King's Own Regiment of Wall Perforators and the gathering professors of extract hood fitting.
:lol:
Been thanked: 2618 times
Installing my heating system included having to drill two 1,200mm long 100mm diameter holes through some poured mass concrete and a wall built from Lewisian Gneiss. I used a Bosch SDS drill, diamond tipped core drills, TCT tipped core drills, a variety of home made extensions and chisels.
I found that the TCT tipped drills will still work tolerably even when down to one tooth remaining and that the diamond drills cut better on hammer. I wasn't concerned about knock out at the end of the holes as they were below ground level. Nor was I concerned about the longevity of the diamond bits, I just wanted the holes drilled. I don't know how many man hours it took but they were all tedious.
I also installed my own gas pipes and appliances. There's no registered gas plumbers on the island and I wouldn't trust the visiting one for the quality of his work. The rental has no gas fitted because of the expense of certification.
If I ever design my own house I'm going for the 'industrial chic' approach. No services will be buried in floors, walls or hidden in lofts (apart from the heat exchanger for the heating system). The workings of the house (it being a 'machine for living in') will be out and proud.
The place might look like the Pompidou Centre. :D
Has thanked: 838 times
Been thanked: 1240 times
Count Steer wrote: Sun Jan 01, 2023 9:53 am If I ever design my own house I'm going for the 'industrial chic' approach. No services will be buried in floors, walls or hidden in lofts (apart from the heat exchanger for the heating system). The workings of the house (it being a 'machine for living in') will be out and proud.
I ripped out my hot water tank earlier this year. It joins the bathroom and kitchen and having a service riser is making life so much easier
Has thanked: 145 times
Been thanked: 497 times
Post by Silly Car »
Skub wrote: Sat Dec 31, 2022 6:51 pm I've a cheap SDS like this one. It has seen little use up until now,should do the job.
https://www.screwfix.com/p/erbauer-erh7 ... lsrc=aw.ds
https://www.screwfix.com/p/diamond-core ... ores/8252v
That kit will do everything you need on top of your drill, set the speed to low, turn off hammer ;) and make sure you have the hand grip attached firmly.
Drill a pilot hole all the way through to start with.
Use pilot drill in core bit / arbor to get you started then remove it
Apply reasonable pressure and take your time
Cut form both sides to prevent breakout
Or hire the kit, my local place charges a pittance for the correct drill and core bit
Or get a grown up to help :D
Has thanked: 2407 times
Been thanked: 3635 times
Mussels wrote: Sun Jan 01, 2023 10:03 am
In the house in France I have 500mm thick walls made of big rocks to contend with, so services have to run vertically. I used cable tray (as used for data centre cabling etc.) running top to bottom and then branch off as required. If the cabling/plumbing is done neatly then it does a fair job of 'industrial chic'. You can also suspend cable tray from threaded rod if you want to go the whole hog.
Gregor
Has thanked: 1295 times
Been thanked: 872 times
Post by Gregor »
Being a lazy sod I’d buy a condenser drier instead :thumbup:
DefTrap
Has thanked: 2265 times
Been thanked: 2193 times
Post by DefTrap »
mangocrazy wrote: Sun Jan 01, 2023 12:53 pm
I wanted similar for my rewiring job but my electricien just couldn't get his head round it for some reason. He wouldve been quite happy with effing nasty plastic ducting though! In the end we opted for a minimal amount of chasing but tbh he made a bit of an arse of that too. Once I finished weeping I just decided I would just le him do it and fix it myself in my own time. In his defence, the rewiring job has been 100% reliable.
When it comes to drilling big old holes in walls I'm fairly lucky as my place is sandstone, so relatively soft although pretty thick.
DefTrap wrote: Sun Jan 01, 2023 2:17 pm
At the previous house I got a (very large, national) company to quote for fitting an alarm system. I thought, 'This'll be a doddle, single storey building, suspended ceilings throughout, piece of cake'. The blokes who turned up to spec the job went 'Oooerrr, don't know about that'.
I asked them how they normally did it and they said that they normally 'just' go upstairs, take the flooring up and do the cabling. I thanked them for their time, hustled them off the premises and got a local company to do it. Their chap said 'Woohoo! Suspended ceilings. Piece of cake'. :D
Before I retired I worked in the IT department of a major UK Bank, and most of the time in offices housed in the data centre. By a happy coincidence I needed large amounts of cable tray just as the Facilities department were getting rid of a load of unused cable tray that wasn't to the latest spec. So I got a vanload of the stuff for free. I've still got some bits left but I'm astonished at how much the gaff has swallowed.
Our place has all sorts of types of rocks/boulders in the walls. A fair amount are soft enough to drill, some shatter as soon as you go near them with a hammer drill and on some a hammer drill just bounces off, making sparks...
DefTrap
Post by DefTrap »
Count Steer wrote: Sun Jan 01, 2023 2:28 pm
Honestly the ideas they came up with to conceal some of the cabling were horrific. (I'd intended to be there to 'supervise' and answer questions but all the moving dates, and hence the window for rewiring, got shifted). Multiple holes drilled through joists, chasing done in nice stone door surrounds when 6 inches in the horizontal would have been less moronic. Should've strangled him.
Has thanked: 1508 times
Been thanked: 1415 times
Out here in the desert the vents attract snails..
Has thanked: 9834 times
Been thanked: 10147 times
ZRX61 wrote: Tue Jan 03, 2023 4:18 pm Out here in the desert the vents attract snails..
That's dinner sorted then. :thumbup:
MyLittleStudPony
Has thanked: 617 times
Been thanked: 407 times
Post by MyLittleStudPony »
Two jet skis. :(
MyLittleStudPony wrote: Tue Jan 03, 2023 6:19 pm Two jet skis. :(
Didja mean to post that in the 'covers or garage' thread? :lol:
Bigyin
Has thanked: 1412 times
Been thanked: 2680 times
Post by Bigyin »
Gregor wrote: Sun Jan 01, 2023 1:28 pm Being a lazy sod I’d buy a condenser drier instead :thumbup:
Thats what i did ....... no vents, pipes or hassle :thumbup:
Big hole attained.
It took bloody ages,but a neat enough job. Knackered now!
So did you hire or buy the kit? Top job, very neat. :thumbup:
