Multi meter in series with the battery (with everything off - if you try to switch it on, or heaven forbid start the bike you'll fry the meter).
( If you are using an old school meter try a quick dab and if the meter wraps around the end stop, pull it off sharpish
If you can see some current drain, try removing fuses to see what is pulling current.
If *all* the fuses are out and its still pulling current it could be the regulator - on mine the epoxy was bulging so it was a dead giveaway once i'd unbolted it from the frame.
