I'll get you at playtime.Le_Fromage_Grande wrote: Wed Apr 27, 2022 1:51 pmWere your leathers filled with helium?Yorick wrote: Wed Apr 27, 2022 1:41 pm I never had brake problems in 15 years of hauling down 14 stones of gorgeous Yorkshireman from 150 at least 100 times a day.
All on Dot4![]()
Brake Fluid
- Has thanked: 12615 times
- Been thanked: 8540 times
Re: Brake Fluid
Re: Brake Fluid
No, probably not!weeksy wrote: Wed Apr 27, 2022 1:36 pmI doubt in the real world outside of a trackday that ever happened to anyone.Mr. Dazzle wrote: Wed Apr 27, 2022 1:34 pm TBF though, if you are gonna experience an issue, it's likely to be the brakes suddenly not working very well 'cause the fluid is boiling - not really the sort of thing you want to encounter when you're not expecting it![]()
I was more thinking of the counter argument to the "if it ain't break" view point. If it is broke, you ain't gonna know about it until it's too late!
I've always changed mine at the same time as the pads pretty much (not doing trackdays though, so that's much more infrequent). It's such a small thing to do and the consequences of it going wrong - however unlikely that is - are so high it's an easy decision for me.
- dern
- Has thanked: 1184 times
- Been thanked: 2277 times
Re: Brake Fluid
I change mine every year and at least twice a year on the track bike.
I'm sure it's fine to leave it longer but it takes ten minutes, keeps the performance tip top and stops the components manking up.
Re: Brake Fluid
I've had the GSXR about 3 years now and thinking about trashing the ABS.
Will get the fluid changed then
- dern
Re: Brake Fluid
Yeah, the last thing you want to experience when it comes to brake maintenance is regretMr. Dazzle wrote: Wed Apr 27, 2022 2:04 pm I was more thinking of the counter argument to the "if it ain't break" view point. If it is broke, you ain't gonna know about it until it's too late!![]()
- Has thanked: 602 times
- Been thanked: 4529 times
Re: Brake Fluid
I'd love to know how people do a complete brake fluid change on a modern superbike in 10 minutes, I don't think I could do the front brake on a 250 LC in 10 minutes.
Re: Brake Fluid
I could do an LC or GSXR in less than 5 mins.Le_Fromage_Grande wrote: Wed Apr 27, 2022 2:42 pm I'd love to know how people do a complete brake fluid change on a modern superbike in 10 minutes, I don't think I could do the front brake on a 250 LC in 10 minutes.
Edit. The current gsxr has bleed nipples on inside, so maybe 10 mins.
- Been thanked: 15500 times
Re: Brake Fluid
MityvacLe_Fromage_Grande wrote: Wed Apr 27, 2022 2:42 pm I'd love to know how people do a complete brake fluid change on a modern superbike in 10 minutes, I don't think I could do the front brake on a 250 LC in 10 minutes.
- Ditchfinder
- Has thanked: 861 times
- Been thanked: 1069 times
Re: Brake Fluid
Do the £20 kit vacuum pump bleeders on Amazon work just as well?
Re: Brake Fluid
I've got one, it's a bit shit, it's very good for syphoning petrol out of a bike into the lawn mower, so not a total waste of money.Ditchfinder wrote: Wed Apr 27, 2022 3:49 pm Do the £20 kit vacuum pump bleeders on Amazon work just as well?
- MrLongbeard
- Has thanked: 779 times
- Been thanked: 3221 times
Re: Brake Fluid
I've been looking.Ditchfinder wrote: Wed Apr 27, 2022 3:49 pm Do the £20 kit vacuum pump bleeders on Amazon work just as well?
Apparently they're all crap, mostly because the rubber adaptors don't seal on the bleed nipple so you don't get a good vacuum and so they don't work.
I'll be going for one but putting a piece of silicone hose between the adaptor and bleed nipple what for getting a good seal, that should do the job.
What can't be sucked out without cycling the ABS block can stay as far as I'm concerned, that little bit shouldn't contaminate the new fluid that much
- Ditchfinder
Re: Brake Fluid
Let us know how you get on - I don't have ABS to worry about on my relicsMrLongbeard wrote: Wed Apr 27, 2022 4:27 pmI've been looking.Ditchfinder wrote: Wed Apr 27, 2022 3:49 pm Do the £20 kit vacuum pump bleeders on Amazon work just as well?
Re: Brake Fluid
This is exactly the problem my one has, and air ends up getting sucked back into the caliper, tried the silicone hose thing, didn't work, there's too much suction.MrLongbeard wrote: Wed Apr 27, 2022 4:27 pmI've been looking.Ditchfinder wrote: Wed Apr 27, 2022 3:49 pm Do the £20 kit vacuum pump bleeders on Amazon work just as well?
- MrLongbeard
Re: Brake Fluid
Will do, if I remember, it's not something I'm planning to do until at least the end of this seasonDitchfinder wrote: Wed Apr 27, 2022 4:37 pmLet us know how you get on - I don't have ABS to worry about on my relicsMrLongbeard wrote: Wed Apr 27, 2022 4:27 pmI've been looking.Ditchfinder wrote: Wed Apr 27, 2022 3:49 pm Do the £20 kit vacuum pump bleeders on Amazon work just as well?
What can't be sucked out without cycling the ABS block can stay as far as I'm concerned, that little bit shouldn't contaminate the new fluid that much![]()
- MrLongbeard
Re: Brake Fluid
I'll give it a go anywho, I've got some pretty thick walled stuff that should stand up to itLe_Fromage_Grande wrote: Wed Apr 27, 2022 4:39 pmThis is exactly the problem my one has, and air ends up getting sucked back into the caliper, tried the silicone hose thing, didn't work, there's too much suction.MrLongbeard wrote: Wed Apr 27, 2022 4:27 pmI've been looking.Ditchfinder wrote: Wed Apr 27, 2022 3:49 pm Do the £20 kit vacuum pump bleeders on Amazon work just as well?
- DefTrap
- Has thanked: 1838 times
- Been thanked: 1468 times
Re: Brake Fluid
If it's just a flush, then I can do it both ends of the bike in 10 minutes with this https://www.ebay.co.uk/itm/200345014236
With the system empty it's slightly more tricky but not overly so
Re: Brake Fluid
I used to have one of them. Cool things.DefTrap wrote: Wed Apr 27, 2022 5:20 pm If it's just a flush, then I can do it both ends of the bike in 10 minutes with this https://www.ebay.co.uk/itm/200345014236
Last time I just put my thumb over the end
- dern
Re: Brake Fluid
I use one of these attached to my compressor...Le_Fromage_Grande wrote: Wed Apr 27, 2022 2:42 pm I'd love to know how people do a complete brake fluid change on a modern superbike in 10 minutes, I don't think I could do the front brake on a 250 LC in 10 minutes.
Really quick and effective.
Demannu
- Has thanked: 65 times
- Been thanked: 1234 times
Re: Brake Fluid
Rescuing the Smix monster last autumn caused a bit of a twitch in the sphincter re cooked brakes in the moho. New pads and discs fitted earlier in the year, so all good mechanically, but after 15 hairpins the pedal was going to the floor, and that was using the gears properly as well.weeksy wrote: Wed Apr 27, 2022 1:36 pmI doubt in the real world outside of a trackday that ever happened to anyone.Mr. Dazzle wrote: Wed Apr 27, 2022 1:34 pm TBF though, if you are gonna experience an issue, it's likely to be the brakes suddenly not working very well 'cause the fluid is boiling - not really the sort of thing you want to encounter when you're not expecting it![]()
I'd have thought a brake 'failure' for whatever reason on the road would be more common.... but still, exceptionally rare.
So it does happen on the road!
Re: Brake Fluid
Yeah I've had the same thing driving the works Van across MK. Brakes just gave out completely at about Roundabout 11.
Fortunately there was no one coming
