Brake Fluid
Has thanked: 779 times
Been thanked: 3216 times
Brake Fluid
OK, so excluding racers & track day usage, do you change yours regularly?
It's come up over on the Harley forum that it should be done every 2 years or risk borking the ABS unit and dying in fiery flames :flame:
I've got to admit, but aside from the odd topping off I've never done a full or even partial brake juice change :silent:
Re: Brake Fluid
Depends.
If I buy a bike and there's no proof of it ever been done, I'll change it. If not then two years sounds about right, no idea if it borks the ABS valve block if you don't.
It's hydroscopic so it can only be absorbed water in the fluid that cause s problems?
If you change it at home you'll probably never do a complete change on an ABS equipped bike, without the software and cable to get it to cycle the pump you'll never get fluid pushed through the pump. You can change it, go for a ride and make the ABS kick in to dilute it a bit and change it again. I think.
Re: Brake Fluid
My FZ750 has brake fluid from 1985 in the rear brake, works like it should.
Been thanked: 15493 times
Re: Brake Fluid
No, but certainly every 2 years would be a minimum for me.
Mtb brakes are 2 monthly
Re: Brake Fluid
If it looks manky I'll change it. On most of my bikes I've spent time trying to improve the brakes,so old fluid is a casualty of that procedure. I went through gallons of the stuff on my ZZR1100. :roll:
It's easy enough to do and BF is cheap,but for road use it doesn't get a hard time anyway.
Has thanked: 12607 times
Been thanked: 8538 times
Re: Brake Fluid
I used to get it changed when it was serviced.
Ditchfinder
Has thanked: 861 times
Been thanked: 1069 times
Re: Brake Fluid
Post by Ditchfinder »
weeksy wrote: Tue Apr 26, 2022 8:01 pm No, but certainly every 2 years would be a minimum for me.
Wait, what you flush brake fluid every 2 months on your mtb?
Re: Brake Fluid
Ditchfinder wrote: Tue Apr 26, 2022 10:27 pm
That's correct mate... on both Shimano setups and SRAM.
Re: Brake Fluid
KungFooBob wrote: Tue Apr 26, 2022 7:22 pm It's hydroscopic so it can only be absorbed water in the fluid that cause s problems?
Yeah that. The primary concern is that the boiling temperature of the fluid drops. Hence why the cheese gets away with his 30 year old rear brake fluid - it never becomes hot enough to discover an issue.
I suppose there might also be an additional concern with dissolved water causing corrosion or sealing issues in sensitive ABS units.
Re: Brake Fluid
Nearer 40 years old actually, and as I barely use the rear brake on the FZ, it's never going to boil, the fluid is a nasty brown colour, but FZ rear brakes are an utter barstard to change the fluid in without getting air into the system - so while it isn't broken, I'm not fixing it.
BTW while the whole rear brake assembly is from a 1985 bike, it came off a brand new bike in 1985 without being used until I got it a couple of years ago, and since then it's done about 1000 miles, the pads are also from 1985, but had no use when I got it, funny really, it's the oldest part on the bike, but the lowest mileage, most of the rest of the bike has done 65,000 miles.
Re: Brake Fluid
I was born in 1984, so I don't like to think of 1985 as being nearly 40 years ago :lol:
wull
Has thanked: 979 times
Been thanked: 1858 times
Re: Brake Fluid
Post by wull »
Once a year for me depending on usage with regards to track etc and also dependant on what mods I do. For example if I fit a Brembo or braided lines or anything like that then it will get fresh fluid.
Ditchfinder
Re: Brake Fluid
Starting to think I don't change my fluid often enough - as I haven't ever :oops:
Re: Brake Fluid
Ditchfinder wrote: Wed Apr 27, 2022 1:30 pm Starting to think I don't change my fluid often enough - as I haven't ever :oops:
If it ain't broken, don't fix it :)
Re: Brake Fluid
TBH if you're not experiencing an issue, do you really need to ?
Re: Brake Fluid
TBF though, if you are gonna experience an issue, it's likely to be the brakes suddenly not working very well 'cause the fluid is boiling - not really the sort of thing you want to encounter when you're not expecting it :D
Re: Brake Fluid
Mr. Dazzle wrote: Wed Apr 27, 2022 1:34 pm TBF though, if you are gonna experience an issue, it's likely to be the brakes suddenly not working very well 'cause the fluid is boiling - not really the sort of thing you want to encounter when you're not expecting it :D
I doubt in the real world outside of a trackday that ever happened to anyone.
I'd have thought a brake 'failure' for whatever reason on the road would be more common.... but still, exceptionally rare.
Ditchfinder
Re: Brake Fluid
As I pootle rather than rag I doubt I could even get it tepid let alone boil it.
I'm a different rider on an MTB though but have only ever flushed the Dot4 out of a pair of old Hope brakes, all my mineral oil (Clarks / Shimano) sets just get topped off when they need a bleed. Never lost a brake through heat, only crappy shimano piston seals leaking or ripping a hose off in a crash.
The front brake on the Triumph probably needs doing as it's a bit spongy but I keep putting it off as I'm certain the reservoir cap bolts will be seized and it will turn into a ball ache of a job (Can we have an angry spanner waving banana emoji please ?)
Re: Brake Fluid
I never had brake problems in 15 years of hauling down 14 stones of gorgeous Yorkshireman from 150 at least 100 times a day.
All on Dot4 :)
Re: Brake Fluid
Yorick wrote: Wed Apr 27, 2022 1:41 pm I never had brake problems in 15 years of hauling down 14 stones of gorgeous Yorkshireman from 150 at least 100 times a day.
All on Dot4 :)
Were your leathers filled with helium? :D
