The preload ring on the Tracer 900 I rode in NZ in 2019 was inaccessible. As the shock softened up with two people plus luggage, the preload really needed upping and without tools I couldn't do it. By the end of the trip I was dragging the centre stand.Yorick wrote: Sat Nov 14, 2020 4:27 pm To show some Japanese stupidity, the bleed valves on the current GSXR are on the inside.
Farking nightmare to get the tube on. Even worse getting 10mm spanner in to open and close it.
Totally stupid idea.
Swapping an XJ6 rear shock - how hard can it be?
- Has thanked: 2908 times
- Been thanked: 1678 times
- Contact:
Re: Swapping an XJ6 rear shock - how hard can it be?
- Has thanked: 12609 times
- Been thanked: 8539 times
Eat more salad.The Spin Doctor wrote: Sat Nov 14, 2020 4:44 pmThe preload ring on the Tracer 900 I rode in NZ in 2019 was inaccessible. As the shock softened up with two people plus luggage, the preload really needed upping and without tools I couldn't do it. By the end of the trip I was dragging the centre stand.Yorick wrote: Sat Nov 14, 2020 4:27 pm To show some Japanese stupidity, the bleed valves on the current GSXR are on the inside.
Beancounter
- Has thanked: 3130 times
- Been thanked: 684 times
Not just the Tracer 900, the MT09 is similar, it's fit and forget. My R1150GS is similar too though the OEM shock has a hydraulic preload adjuster. I'd just got my first Nitron and it was sprung for me, didn't see the point of paying £250 for an HPA. Three weeks later I got a girlfriend who decided she'd rather commute with me on the bike than on the train.The Spin Doctor wrote: Sat Nov 14, 2020 4:44 pmThe preload ring on the Tracer 900 I rode in NZ in 2019 was inaccessible. As the shock softened up with two people plus luggage, the preload really needed upping and without tools I couldn't do it. By the end of the trip I was dragging the centre stand.Yorick wrote: Sat Nov 14, 2020 4:27 pm To show some Japanese stupidity, the bleed valves on the current GSXR are on the inside.
- Contact:
If I remember right, the Tracer 900 GT has a remote adjuster. It's outrageous that it's only on the more expensive model.Beancounter wrote: Sat Nov 14, 2020 5:05 pm
Not just the Tracer 900, the MT09 is similar, it's fit and forget. My R1150GS is similar too though the OEM shock has a hydraulic preload adjuster. I'd just got my first Nitron and it was sprung for me, didn't see the point of paying £250 for an HPA. Three weeks later I got a girlfriend who decided she'd rather commute with me on the bike than on the train.![]()
millemille
- Has thanked: 335 times
- Been thanked: 994 times
Every vehicle is designed around what is known as the "Nexus component".
On Land Rover series and defenders it is the screen wash bottle. You have to take the whole vehicle apart in order to change the bottle when it splits.
It is the very first component around which the rest of the vehicle is then design and assembled.
Sounds like the nexus component on the OP's bike as the ABS unit....
- Been thanked: 15498 times
On the KTM 690 it was the bracket between the radiator and the exhaust header, I'm sure I even had to take the zx6 apart to get to it!millemille wrote: Sun Nov 15, 2020 7:39 pm Every vehicle is designed around what is known as the "Nexus component".
millemille
LOLweeksy wrote: Sun Nov 15, 2020 8:11 pm
I knew you'd be funny eventuallyweeksy wrote: Sun Nov 15, 2020 8:11 pmOn the KTM 690 it was the bracket between the radiator and the exhaust header, I'm sure I even had to take the zx6 apart to get to it!millemille wrote: Sun Nov 15, 2020 7:39 pm Every vehicle is designed around what is known as the "Nexus component".
