NBT: I've bought a Honda!
- Has thanked: 20876 times
- Been thanked: 13695 times
Re: NBT: I've bought a Honda!
Decided the Buell pegs probably won't lower the pegs enough to make a difference and I'd have to file them down to get them to fit. So I decided I'd try a set of 40mm lowering ones. The gear lever can adjust enough to suit this but not sure the rear brake pedal can be lowered by that much? I'll see how it all works out when they get here...
- Been thanked: 15498 times
Do you use the rear brake ? Apart from sitting in a queue waiting to go out on track, i don't think i've ever used it.
Yes, probably as much as the fronts!! I trail brake a lot and drag with it when slow speed, feet up manoeuvring..weeksy wrote: Wed Jun 21, 2023 10:12 am Do you use the rear brake ? Apart from sitting in a queue waiting to go out on track, i don't think i've ever used it.
- Has thanked: 602 times
- Been thanked: 4529 times
I use the back brake a lot, I never used to use it on race replicas, but on the GSX I brake with both front and back, it stops better using both.weeksy wrote: Wed Jun 21, 2023 10:12 am Do you use the rear brake ? Apart from sitting in a queue waiting to go out on track, i don't think i've ever used it.
- Been thanked: 9496 times
My GS has linked brakes so no need to used the back in normal use.
My Bullet you have to use both if you ever want to stop.
On the GSRX11 its only used for skids.
I promised myself I wouldnt spend any money on this in case I shifted it on, but I feel I need to take a shot at making it better before deciding its future. So, the custom mirrors
absolutely suck as do the horrible after market stubby levers. Hopefully, I've bagged some OEM ones to replace them with and should reclim the purchase price, or some of it, when I sell the custom crapon.
A strange thing about this bike is the dash is very hard to see! I always seem to be staring at reflective light and cant see the actual displays?? Cant recall having that problem before? Maybe a screen would help?
- Has thanked: 4088 times
- Been thanked: 2513 times
I've seen reviews on bikes where one of the criticism's is screen glare,so it is a known problem.Have a search for screen protector film or anti glare film.
Thanks Ill look into that.Bustaspoke wrote: Thu Jun 22, 2023 7:37 am I've seen reviews on bikes where one of the criticism's is screen glare,so it is a known problem.Have a search for screen protector film or anti glare film.
Ordered an ipad one from Temu for £3.48! Will cut that to size and see if it works or even helps.Bustaspoke wrote: Thu Jun 22, 2023 7:37 am I've seen reviews on bikes where one of the criticism's is screen glare,so it is a known problem.Have a search for screen protector film or anti glare film.
- Tricky
- Has thanked: 3045 times
- Been thanked: 3309 times
Perhaps a bit of a drastic solution to the clocks visibility issue, but you could out the current CB1000, buy the one below ( currently for sale on PB Forum - looks roomy, has old school clocks, a naughty pipe and is very you I reckonTaipan wrote: Thu Jun 22, 2023 10:24 amThanks Ill look into that.Bustaspoke wrote: Thu Jun 22, 2023 7:37 am I've seen reviews on bikes where one of the criticism's is screen glare,so it is a known problem.Have a search for screen protector film or anti glare film.I need something for sure, as there are so many bastard speed cameras on my commute I need to be able to see the speedo lol!
Chemist on PB Forum wrote:Rare bike, not often seen.
CB1300 forks, Renthal bars
VTR wheels to wear proper sized tyres
Nissin 4 pot brakes, braided lines
Ported head, adjustable cam sprockets
Two Brothers full race exhaust
This is a really well put together bike, looks great, has got all the parts to make it handle and it's very fast and torquey.
Clocks have been changed due to a low speed crash.
Have spare carbs, engine gasket set, new braided lines, original clocks and lots more.
£1995
Thanks anyway, but I'd never buy a bike whose seat unit and tank are of equal size!
I struggled riding it today, really struggled as my leg tendons have had enough and the lowered footpegs cant get here soon enough! I'd kinda written it off as soon as I got it tbh, but it is slowly winning me over!
I'll lower the pegs, change the crap mirrors and levers and then see where I am with it.
The Duc is slowly becoming a memory. Where the Honda wins is, I can't believe I can be sitting at 70, roll the throttle off as I approach the 50mph average speed area, sit at 50 then back up to 70 without changing gear! Been a while since I've had this kind of fuelling and I like it!
- Has thanked: 5964 times
- Been thanked: 3573 times
Good init. I think that's what people overlook or mistake as lack of character. They are not only so, so easy to ride, but also incredibly good at the same time. On mine on a twisty road I can leave it in 2nd/3rd and go nuts or leave it in 6th and mooch or anything in between. Yeah the 690 was rewarding as like a 2 stroke almost you needed to be in the right gear/revs but GSXS has more options when you wanna chill.Taipan wrote: Thu Jun 22, 2023 10:55 am Where the Honda wins is, I can't believe I can be sitting at 90, roll the throttle off as I approach the 50mph average speed area, sit at 50 then back up to 90 without changing gear! Been a while since I've had this kind of fuelling and I like it!![]()
Duly edited...KungFooBob wrote: Thu Jun 22, 2023 11:13 am 90kph, right?
90mph is WAY over the national speed limit.
Good job I got a screen grab before you did, I'm composing my email to the Essex Five-o right now.Taipan wrote: Thu Jun 22, 2023 11:23 amDuly edited...KungFooBob wrote: Thu Jun 22, 2023 11:13 am 90kph, right?
90mph is WAY over the national speed limit.![]()
Nah, I'm a face in Essex.KungFooBob wrote: Thu Jun 22, 2023 11:26 amGood job I got a screen grab before you did, I'm composing my email to the Essex Five-o right now.Taipan wrote: Thu Jun 22, 2023 11:23 amDuly edited...KungFooBob wrote: Thu Jun 22, 2023 11:13 am 90kph, right?
OEM mirrors on R&G extensions bought for £30 delivered. OEM levers bought for £20 delivered. Result!
Lowering pegs on their way but I suspect on a slow boat from bat eating land!
It’s really soft so I can’t see how it can do anything but will fit it for a laugh and see if it does!
- Has thanked: 12610 times
- Been thanked: 8539 times
It looks fantastic. Like really coolTaipan wrote: Fri Jun 23, 2023 1:17 pm![]()
