The Triumph
- the_priest
- Has thanked: 2098 times
- Been thanked: 2558 times
Re: The Triumph
The race brake lines have arrived! I also have a new reservoir as the old one leaks. New one is off a 1050 triple and screws down, so a better seal I hope.
- the_priest
Re: The Triumph
Correct. New flange rubber seal/gasket bought. £40 delivered... but the old one may have been the original, so 20 years out of one of those is pretty good. It was still supple, but some of the embedded nuts had broken loose. Filter arrives by Friday as does seal. Then I can get the bike running again. Brake likes, air filter, spark plugs all need to be done as well. No rush.BBB wrote: Wed Dec 08, 2021 9:26 pm Looks like you had to take the plate off the tank, filter change too?
- Has thanked: 8036 times
- Been thanked: 5694 times
Re: The Triumph
inewham wrote: Thu Dec 09, 2021 8:52 am Completely drain the tank, don't leave any fuel in the bottom while you do it (sounds obvious but it is doable) to make sure you get the water out
I poured the last dregs into a jug - after standing for a few minutes it separated and there was a good cupful of water in the bottom. Its the water that makes the tanks swell.
I'm intrigued.
Re: The Triumph
Plastic loves (hates!) a bit of water. Moisture absorption in polymers is a major thing, they pretty much all do it. Even super fancy aerospace carbon fibre has a so called "Hot Wet" performance which is lower than dry properties.
It's standard practice to moisture saturate polymers as part of testing, if you boil plastics for an extended period they take up a few percent of their own weight in water. If you leave them in a 'normal' environment that's vaguely humid they still do it, but just over a longer period.
Re: The Triumph
Cheers. It's a good job I went into technical ceramics not polymers!Mr. Dazzle wrote: Thu Dec 09, 2021 9:52 am Plastic loves (hates!) a bit of water. Moisture absorption in polymers is a major thing, they pretty much all do it. Even super fancy aerospace carbon fibre has a so called "Hot Wet" performance which is lower than dry properties.
- the_priest
Re: The Triumph
Race Brake Lines and new reservoir installed. Bit of a fiddle!
- Been thanked: 15490 times
- the_priest
Re: The Triumph
It is nice to see the bike coming together. Needs an air filter too. The one in there was filthy!
- the_priest
Re: The Triumph
Airbox off. Sparkplugs changed. Airbox needs a good clean, has oil inside it from overflow.
Old Sparkplugs. A bit grubby I should think.... Fitted the DPR9EA-R as recommended plugs... time will tell.
Just waiting for fuel filter, air filter and time to do indicators Heading out to a meeting in a short while, so that is it until filters arrive.
- the_priest
Re: The Triumph
Thanks, that is a good tip. I'll have a look for where I can get new ones.inewham wrote: Thu Dec 09, 2021 5:57 pm You might consider replacing the corrugated air hoses they crack and leak air
- Has thanked: 3644 times
- Been thanked: 2502 times
Re: The Triumph
You're missing a spark plug!
- the_priest
Re: The Triumph
Never!!! I've just gone back to a triple from an IL4 as I was missing character! Come to the Triple side, we have noise, character, sensation and real road power!
- Been thanked: 9495 times
Re: The Triumph
My Triumph triple wasn't the 955 (only the 800), but it didn't have as much speed as an IL4 or as much character as a twin... it was a compromise.
I did ride a 1050 Speedtrip once, but it was back to back with a KTM 950SM, so I remember very little about the Triumph.
- Has thanked: 602 times
- Been thanked: 4528 times
Re: The Triumph
Your plugs were fucked and oil in the air box is usually a sign of a blocked air filter (it sucks oil up the breather) but it could be shagged rings, oil blown up the breather.
Re: The Triumph
Same with moto guzzi, tank on the Centauro swelled and then hit the stanchions lock to lock which is MOT failureEither way its not good to have a cup full of water in there and Triumph and Ducati tanks are known to swell. Mine didnt blister like some but it got too long to go back on the fixings.
- Has thanked: 2852 times
- Been thanked: 3504 times
- the_priest
Re: The Triumph
Blocked air filter is my bet at the moment. It was really bad. The tank has been fine. No blisters or swelling. E5 petrol only. I've had triples before and am more than happy with their character!
- the_priest
Re: The Triumph
New fuel filter fitted. New gasket fitted. Put the bolts in the holes first, then offer it up to the tank. It is easier to get it lined up that way and know you don't have pinch points. I've let the tank sit for 20 minutes with fuel in that lowest point and no leaks. Just waiting for air filter now.
Fitted to the tank now.
Airbox is now back on neatly with all connections done up. Pipercross airfilter on the way.
Re: The Triumph
My tank is deffo distorted and blistering, you've apparently been lucky.
A full respray is on the cards for mine anyway, so I reckon maybe I should be on the lookout for a good tank
