The Triumph
- the_priest
- Has thanked: 1874 times
- Been thanked: 2171 times
Re: The Triumph
New fuel quick release connectors here. Have to get the broken one out now somehow. It is fragmenting. Fortunately I have a tapping set, so may be able to chase it out bit by bit. Patience is the game for this one. Fuel filter will be here in a few days as well. I've got the fuel pump flange rubber gasket arriving later on as well as the old one was a mess. Must be the original one.
- the_priest
Re: The Triumph
Bits fitted. Yes, one is opposite facing to the other. Easier to release that one from that angle.
- the_priest
Re: The Triumph
The race brake lines have arrived! I also have a new reservoir as the old one leaks. New one is off a 1050 triple and screws down, so a better seal I hope.
- the_priest
Re: The Triumph
Correct. New flange rubber seal/gasket bought. £40 delivered... but the old one may have been the original, so 20 years out of one of those is pretty good. It was still supple, but some of the embedded nuts had broken loose. Filter arrives by Friday as does seal. Then I can get the bike running again. Brake likes, air filter, spark plugs all need to be done as well. No rush.
- Has thanked: 6382 times
- Been thanked: 4765 times
Re: The Triumph
That's a new one to me. Plastics and water don't usually interact particularly, organic solvents on the other hand...inewham wrote: ↑Thu Dec 09, 2021 8:52 am Completely drain the tank, don't leave any fuel in the bottom while you do it (sounds obvious but it is doable) to make sure you get the water out
I poured the last dregs into a jug - after standing for a few minutes it separated and there was a good cupful of water in the bottom. Its the water that makes the tanks swell.
I'm intrigued.
- Has thanked: 2552 times
- Been thanked: 6262 times
Re: The Triumph
Plastic loves (hates!) a bit of water. Moisture absorption in polymers is a major thing, they pretty much all do it. Even super fancy aerospace carbon fibre has a so called "Hot Wet" performance which is lower than dry properties.
It's standard practice to moisture saturate polymers as part of testing, if you boil plastics for an extended period they take up a few percent of their own weight in water. If you leave them in a 'normal' environment that's vaguely humid they still do it, but just over a longer period.
Re: The Triumph
Cheers. It's a good job I went into technical ceramics not polymers!Mr. Dazzle wrote: ↑Thu Dec 09, 2021 9:52 am Plastic loves (hates!) a bit of water. Moisture absorption in polymers is a major thing, they pretty much all do it. Even super fancy aerospace carbon fibre has a so called "Hot Wet" performance which is lower than dry properties.
- the_priest
Re: The Triumph
Race Brake Lines and new reservoir installed. Bit of a fiddle!
- Has thanked: 5455 times
- Been thanked: 13102 times
- the_priest
Re: The Triumph
It is nice to see the bike coming together. Needs an air filter too. The one in there was filthy!
- the_priest
Re: The Triumph
Airbox off. Sparkplugs changed. Airbox needs a good clean, has oil inside it from overflow.
Old Sparkplugs. A bit grubby I should think.... Fitted the DPR9EA-R as recommended plugs... time will tell.
Just waiting for fuel filter, air filter and time to do indicators Heading out to a meeting in a short while, so that is it until filters arrive.
- the_priest
Re: The Triumph
Thanks, that is a good tip. I'll have a look for where I can get new ones.
- MingtheMerciless
- Has thanked: 2947 times
- Been thanked: 1884 times
Re: The Triumph
You're missing a spark plug!
- the_priest
Re: The Triumph
Never!!! I've just gone back to a triple from an IL4 as I was missing character! Come to the Triple side, we have noise, character, sensation and real road power!
- Been thanked: 7539 times
Re: The Triumph
My Triumph triple wasn't the 955 (only the 800), but it didn't have as much speed as an IL4 or as much character as a twin... it was a compromise.
I did ride a 1050 Speedtrip once, but it was back to back with a KTM 950SM, so I remember very little about the Triumph.
- Been thanked: 4125 times
Re: The Triumph
Your plugs were fucked and oil in the air box is usually a sign of a blocked air filter (it sucks oil up the breather) but it could be shagged rings, oil blown up the breather.
Re: The Triumph
Same with moto guzzi, tank on the Centauro swelled and then hit the stanchions lock to lock which is MOT failure tanks I have for the 1200 sport, one is blistered and the other one touches the bar risers on lock to lock, I'm hoping a long while off the bike will shrink the better one back to shape, new tanks are £2k plusEither way its not good to have a cup full of water in there and Triumph and Ducati tanks are known to swell. Mine didnt blister like some but it got too long to go back on the fixings.
- Has thanked: 1751 times
- Been thanked: 2087 times
- the_priest
Re: The Triumph
Blocked air filter is my bet at the moment. It was really bad. The tank has been fine. No blisters or swelling. E5 petrol only. I've had triples before and am more than happy with their character!
