Honda mini bikes.
Been thanked: 3505 times
Re: Honda mini bikes.
Straps will hooks around metal frame of rack. But the possible concern you've given me is will the straps cut into rear edge of plastic, if so I'll put some pipe foam or summot like on that rear edge to stop wear, possibly maybe. 👍
Those lids are quite brittle,not a lot of give in them. We have quite a few in the roofspace and some lids break in normal operation.
Has thanked: 10964 times
Been thanked: 3996 times
Skub wrote: Wed Mar 25, 2026 4:19 pm Those lids are quite brittle,not a lot of give in them. We have quite a few in the roofspace and some lids break in normal operation.
yeah same, that's why I asked the question. TBH, you'd want something more like a plastic breadboard (ie about 1/2" thick-ish)
It's not taking much weight, it's to stop bag droop. I've stuck a A4 size piece of black poly plastic stuff underneath to give it a bit of firmness. It's only the widest couple of inches where it's on it's own.
I could just buy a piece cut to size and thickness but that's equivalent to 4 bottles of Shepherd Neame, ain't happening. 👍
A_morti
Has thanked: 412 times
Been thanked: 824 times
Post by A_morti »
That'll break, and it won't happen anywhere convenient.
Get a beer crate and be done.
Has thanked: 8041 times
Been thanked: 5695 times
You could probably stop the bag drooping at the ends if you packed a length of wood inside it at the bottom.
Maybe.
Perhaps.
Or simply strap it underneath the bag?
I've found something in the oven that'd do the job aswel. 🤫
Has thanked: 12608 times
Been thanked: 8539 times
Dodgy69 wrote: Wed Mar 25, 2026 6:44 pm I've found something in the oven that'd do the job aswel. 🤫
Sausage casserole?
Has thanked: 20863 times
Been thanked: 13684 times
A bit more usable than the 4 cyl one!
Well........due to the overwhelming positivly negative feedback for my prototype rack extension, I've been busy this morning with my 2nd incarnation, made of wood. 👍
Rooting through the shed i found some ply 🥳. Cut 500 x 200, took the edge off, bit of a rub down and here we have it. Its 14mm thick and strong as an ox.
Its only gonna be used when needed so god knows when tbh, but its ready and willing.
I also have a piece ready for when I use the big bag. 👇
and just a reminder of the PT1 masterpiece.
As you were...
Buckaroo
Has thanked: 1048 times
Been thanked: 1108 times
Post by Buckaroo »
I quite like the plank. Very aero and if set correctly will help keep the rear from spinning up when given the beans. Coat it in carbon fibre vinyl wrap and you're on to a winner 🏆
:thumbup:
What colour are you going to paint it?
Rockburner wrote: Thu Mar 26, 2026 12:50 pm :thumbup:
It's staying in its natural form and if I fancy a buttered scone or slice of tiger loaf with some dairylea while I'm out, the cutting board is available. 👌
That wooden do.
You're doing it wrong...
A_morti
Post by A_morti »
Have you considered a personal plate?
Monkeys been out for 80 odd miles today. Hail, sleet, strong gusts, heavy rain, cold with lovely sunshine, perfect. 🙂👍
Local hill's with lunch in Clun. Ham n cheese toastie and tea. Pic looking over the Stiperstones.
Has thanked: 4088 times
Fair play getting out in those conditions,around here it's been windy as feck all day with the occasional shower thrown in.You're Monkey bike would have struggled riding into the headwind!
Yep, it turns into a 4 speed in the slightest headwind or incline. 3 speed with both.
Hang on a minute 😮
