Chain cleaning when washing the bike
- Trogladyte
- Has thanked: 68 times
- Been thanked: 89 times
What do you do?
I don't like cleaning the chain, and then washing the bike, as I worry I am washing the lube off the chain. But I equally don't like washing the bike, and then doing the chain, as its difficult not to get the rear wheel and swingarm dirty again.
But I usually go with the latter. What's your process?
Re: Chain cleaning when washing the bike
I scrub the chain and sprockets with paraffin to loosen all the grime (also good for removing tar spots from exhausts). Rinse with the hose then wash the whole bike.
As soon as it's dry the chain gets re-lubed first, then the rest of the bike gets polished/Moto Protected.
- Been thanked: 7530 times
- Has thanked: 9828 times
- Been thanked: 10145 times
If you aren't using that aerosol sticky-shit lube it makes cleaning a lot easier and less messy.
Chainsaw oil works well for me for lube and paraffin for cleaning. Much the same as Doc.
- Has thanked: 5451 times
- Been thanked: 13087 times
- Has thanked: 2636 times
- Been thanked: 1523 times
I use gear oil. Any spatter just wipes off again.
- Has thanked: 1746 times
- Been thanked: 2085 times
I just lube when it starts getting dry. Paraffin clean when it gets proper shitty. 1 or 2 times a year. I'm a 4k a year man.
- Has thanked: 25 times
- Been thanked: 54 times
Old fashioned EP90 is what the race team lads all use and I have on the ones in the garage.
Wipe off any excess and ride it.
- Bigyin
- Has thanked: 1412 times
- Been thanked: 2680 times
Clean the bike, then clean the chain with chain cleaner, brush and wipes. After that lube the chain on the inside run followed by a quick wipe of the rear wheel after a spin round in case it flicks off onto the wheel
- Has thanked: 599 times
- Been thanked: 2443 times
- Cousin Jack
- Has thanked: 2551 times
- Been thanked: 2286 times
