Isn't it that the 'body under' is the biggest pressing, that's then common across ranges (eg Octavia Golf Leon) with different panels?Mr. Dazzle wrote: Mon Jul 19, 2021 10:50 am Car's haven't really been monocoque for a long time. They're partial monocoque, partial spaceframe hybrids. So if you look at a so called "Body in White" you can see that some bits are like stressed bodywork and some bits are struts etc.
A question about gear usage.
- Has thanked: 7525 times
- Been thanked: 5862 times
Re: A question about gear usage.
It's probably worth mentioning that even if battery packs aren't swappable there's still benefit to be had from everyone using the same one. If you just buy in your pre-existing semi-structural battery and build a car/bike around you can rely on someone elses big old factory and design work to save a lot of money.
- Has thanked: 2908 times
- Been thanked: 1676 times
- Contact:
How did we get here from a discussion on gears?
Electric vehicles won't need gears!
Gear selection is going the same way as the ability to drive a chariot or foresee a squall in time to get t'gallants in.
- Contact:
I'd have a reef in the fore and main topsails too
- Been thanked: 2711 times
Thanks, I was using monocoque in a vague sense.Horse wrote: Mon Jul 19, 2021 11:03 amIsn't it that the 'body under' is the biggest pressing, that's then common across ranges (eg Octavia Golf Leon) with different panels?Mr. Dazzle wrote: Mon Jul 19, 2021 10:50 am Car's haven't really been monocoque for a long time. They're partial monocoque, partial spaceframe hybrids. So if you look at a so called "Body in White" you can see that some bits are like stressed bodywork and some bits are struts etc.
- Has thanked: 1080 times
- Been thanked: 1010 times
on the Jamaica runThe Spin Doctor wrote: Mon Jul 19, 2021 11:31 am I'd have a reefer in the fore and main topsails too![]()
We're going at it the wrong way.Screwdriver wrote: Mon Jul 19, 2021 11:06 am
You Earthlings appear to be quite good at designing weapons so maybe it is possible to design a hot-swap system that "reloads" a car the same way you reload a weapon system. There is nothing new under the Sun and I'm sure this is such an obvious idea, someone has tried it.
With the advent of electric autonomous vehicles, keep the accommodation pod and swap the transport system - Thunderbird 2 style
They never showed how they got Thunderbird 4 back in, which suggests to me there are at least some flaws in the plan.
It would .. ahh .. need Brains, Mr Tracy.Mr. Dazzle wrote: Mon Jul 19, 2021 1:55 pm They never showed how they got Thunderbird 4 back in, which suggests to me there are at least some flaws in the plan.
Same way as they get lifeboats back up the big slope into the shed?Mr. Dazzle wrote: Mon Jul 19, 2021 1:55 pm They never showed how they got Thunderbird 4 back in, which suggests to me there are at least some flaws in the plan.
Not like the one I saw coming in at Selsey - they go full throttle towards the shore and beach, then a caterpiller tractor / trailer (with turntable!) collects it:
It's so much the getting Thunderbird 4 back in the pod which is problematic, it's getting the pod back into Thunderbird 2. They used to just drop the pod into the water - so how do they get it back? If Thunderbird 2 can land on the water why do they just drop everything from the sky in the first place? Seems unnecessarily dangerous.
These are the questions which keep me up at night.
Perhaps T4 works like a little tug boat (not a euphemism) and takes the pod back to Tracy Island?
The amount of underground services nowadays, they'd probably get some geezer with a hard hat and clipboard arrive, "You can't drill there!"
