Perseverance
Wreckless Rat
- Has thanked: 666 times
- Been thanked: 704 times
The Martian
- Has thanked: 841 times
- Been thanked: 564 times
- Been thanked: 9455 times
Re: Perseverance
Depends what you mean by "much" I suppose. All the other rovers have found loads of stuff, but of course not the one big thing they were sent to find.
I'm reasonably sure NASA, SpaceX etc. are run by ten year olds. I suspected it when they originally used the rocket crane, but Elon's cartoon spaceship and giant nets were the final proof.
- MingtheMerciless
- Has thanked: 3633 times
- Been thanked: 2495 times
Re: Perseverance
… "The chances of anything coming from Mars
Are a million to one" he said
Dum, dum, dum!!!
Dum, dum, dum!!!
- Has thanked: 7585 times
- Been thanked: 5913 times
Re: Perseverance
"No-one would have believed ... "MingtheMerciless wrote: Thu Feb 18, 2021 10:05 pm … "The chances of anything coming from Mars
Dum, dum, dum!!!
Going to go to sleep with that album in my head now
Docca
- Has thanked: 729 times
- Been thanked: 1434 times
- Has thanked: 2273 times
- Been thanked: 2654 times
- Bigyin
- Has thanked: 1436 times
- Been thanked: 2738 times
Re: Perseverance
You should have, then you will know where it is to help in any possible rescue in the futureThe Martian wrote: Thu Feb 18, 2021 9:35 pm I was going to watch it, but ironically I couldn't be arsed.
- Yambo
- Has thanked: 512 times
- Been thanked: 1403 times
- Has thanked: 2844 times
- Been thanked: 3495 times
Re: Perseverance
My only interest is to try and discover how, why and perhaps even when Venus became the ultimate example of CO2 driven global warming.
Mars certainly at one stage was much like Earth, a rocky water world but it went the other way. Not sure what the current consensus is regarding early Venus but I'd put money on it too having once been extremely similar to Earth.
Kneerly Down
- Has thanked: 135 times
- Been thanked: 254 times
Re: Perseverance
Venus is fecking hard to work on. The surface conditions are higher pressure than the bottom of the sea and hot enough to melt lead.
NASA actually put out a call for ideas/proposals on how you might make an electronics free rover to work there.
https://www.nasa.gov/feature/jpl/nasas- ... -announced
Re: Perseverance
Don't forget the sulphuric acid atmosphere. The Russians managed to stick a lander on Venus years ago and yet we really know bugger all about it's geology or history.Mr. Dazzle wrote: Fri Feb 19, 2021 9:09 am Venus is fecking hard to work on. The surface conditions are higher pressure than the bottom of the sea and hot enough to melt lead.
Venus, Earth and Mars are all in the "Goldilocks Zone" and yet are vastly different ecologies. There are more hospitable environments on the moons of Jupiter. It could easily be argued Europa is the best candidate for "Earth 2.0" if we really fuck this one up.
- Has thanked: 12556 times
- Been thanked: 8517 times
Wreckless Rat
Re: Perseverance
If Mars was a bit bigger, it would have likely kept its magnetic shield and atmosphere - its not just the location of the planet, but its size as well which is important. Too small and it can't keep an atmosphere, to big and gravity becomes an issue for life (so we believe anyway).DEADPOOL wrote: Fri Feb 19, 2021 9:44 amDon't forget the sulphuric acid atmosphere. The Russians managed to stick a lander on Venus years ago and yet we really know bugger all about it's geology or history.Mr. Dazzle wrote: Fri Feb 19, 2021 9:09 am Venus is fecking hard to work on. The surface conditions are higher pressure than the bottom of the sea and hot enough to melt lead.
As for fucking this planet up, we will, period. We are breeding like rats with no sign of easing. Even if we don't, life cycles are finite imho. Another meteor, another pandemic, or another ice-age/super heating will come along, with or without mankind... and if none of this gets us, the Sun will in the end.
- derek badger
- Has thanked: 1089 times
- Been thanked: 1741 times
- MingtheMerciless
Re: Perseverance
One of the first Russian Landers that survived to the surface suffered the indignity of the lens cap melting onto one of the cameras. Most lasted less than an hour before succumbing to the heat and pressure. Typically 90atm and 485C. Hell world and not the Jungle planet of Edgar Rice Burroughs.
