Does asbestos roofing go porous?
Been thanked: 1228 times
The old corrugated roof of the shed is acting like heavy rain and melting snow soaks through it. Does corrugated asbestos go like that?
Have any of you had any success sealing it with a paint or coating?
I am absolutely not asking for health and safety or environment-saving advice.
Wreckless Rat
Has thanked: 666 times
Been thanked: 704 times
Re: Does asbestos roofing go porous?
Post by Wreckless Rat »
JackyJoll wrote: Tue Feb 16, 2021 2:43 pm The old corrugated roof of the shed is acting like heavy rain and melting snow soaks through it. Does corrugated asbestos go like that?
Yes it can, sealing it can be done with a suitable roofing sealer, but it wont last long. ime
Kneerly Down
Has thanked: 135 times
Been thanked: 254 times
Post by Kneerly Down »
I would use this:
https://www.screwfix.com/p/no-nonsense- ... 5ltr/57474
'Normal' paint/bitumen products rarely work well IME.
Kneerly Down wrote: Tue Feb 16, 2021 3:48 pm I would use this:
Thanks. That does look hopeful.
OBO
Has thanked: 26 times
Been thanked: 16 times
Post by OBO »
They were always porous from new.
Pressure washing makes them worse. (And brittle).
OBO, old industrial roofer. ☺
OBO
Post by OBO »
Bitumen products work fine IF you use an appropriate primer first.
Ditchfinder
Has thanked: 859 times
Been thanked: 1068 times
Post by Ditchfinder »
We just installed a new plastic roof on top of the asbestos roof on our shed. Cheap, easy and has been weatherproof ever since.
The Martian
Has thanked: 841 times
Been thanked: 566 times
Post by The Martian »
Fenacryl, it's a bostik product that you can get in Screwfix for about £40 per 5l. Two will do an average size garage roof.
Just paint it on (do wear gloves it's a liquid polymer and it's a proper cunt to get off your skin).
Get the grey / silver rather than black as it reflects heat and lasts longer. I did an asbestos garage roof in it almost 4 years ago and it's still sound, also used it on flat roofs with good results.
Has thanked: 1080 times
Been thanked: 1010 times
Post by slowsider »
Mine needs scraping again first - looks like sedum at the moment. The moss holds the water long enough to leak through.:(
Ditchfinder wrote: Tue Feb 16, 2021 5:05 pm We just installed a new plastic roof on top of the asbestos roof on our shed. Cheap, easy and has been weatherproof ever since.
But that’s fixing it properly!
Ditchfinder
JackyJoll wrote: Wed Feb 17, 2021 10:25 am
I got a man in to do it (actually 2 of them) hence why it got fixed properly - everything I 'fix' is likely to need further fixes on an ongoing and frequent basis :roll:
Wasn't very expensive either - materials + 1 day labour for 2 of them.
