- Has thanked: 20814 times
- Been thanked: 13617 times
Lutin
- Has thanked: 365 times
- Been thanked: 383 times
- Has thanked: 12563 times
- Been thanked: 8520 times
- Has thanked: 602 times
- Been thanked: 4527 times
- rodbargee
- Has thanked: 397 times
- Been thanked: 1114 times
- Contact:
Tarmacsurfer
- Has thanked: 100 times
- Been thanked: 111 times
Guess the donor bike
(Should be an easy one)
- 144907525_10158535555606154_7340885702300496174_n.jpg (70.31 KiB) Viewed 1314 times
- rodbargee
- Contact:
This is a Sachs rotary
That Hercules appears to have a weird two stroke engine that is intriguing
- DefTrap
- Has thanked: 1838 times
- Been thanked: 1468 times
Still my favourite bike on this thread.
A lot of them (XVs) have been done, few are as good.
- rodbargee
- Contact:
the discussion about the hercules was that the reed valve inlet and odd exhaust positioning was a rotary. I I get that its not like the other one pictured, I would love more info on it. if thE chamber was 90deg putting it inline? and finned without that huge air intake.
- rodbargee
- Contact:
- Has thanked: 7592 times
- Been thanked: 5916 times
The DKW is a rotary like the Norton F1. 'Triangular' piston.
That is a Wankel, and very interesting, I wonder how they've geared the rotor to the clutch.rodbargee wrote: Mon Feb 01, 2021 3:52 pm Here....https://motocrossactionmag.com/bikes-yo ... 02-rotary/
So is the Hercules MX bike, the rotor is vertically above the crankcases.
Ah, ok, apologies. First glance it just looks like a normal 2t barrel at an angle.
- Has thanked: 1059 times
- Been thanked: 1643 times
- Been thanked: 9463 times
- Has thanked: 6116 times
- Been thanked: 15468 times
Stolen off the Benelli website...
754cc Bore x Stroke - 88x62mm Engine layout - Parallel twin Engine details - 4-stroke, liquid cooled, 4 valves per cylinder, dohc Power - 80bhp Torque - 50lb-ft Top speed Est - 135mph Transmission - 6 speed, chain drive Tank size - 15 litres Frame - Steel Trellis Front suspension - 50mm USD hydraulic forks Front suspension - adjustment Compression, rebound and pre-load Rear suspension - Single Hydraulic Shock Rear suspension - adjustment Preload and rebound Front brake - 2 x 320mm discs, mono block Brembo 4 pot calipers Rear brake - 1 x 260mm disc, twin pot caliper Kerb weight - 220kg
I saw another picture of it side on, the tank is quite an odd shape.
