Shoei GT Air 2
- Has thanked: 4360 times
- Been thanked: 2851 times
Shoei GT Air 2
Amy good? Was thinking of getting one.
Is the drop down visor dark enough, looks lighter shade than my current Shark. I note the 2 says the visor is longer than the original as some users said the visor was too short.
Re: Shoei GT Air 2
Have you fitted comms to yours? I already have a Scala Rider Q Solo which I'm gonna stick with as only use it for Sat Nav instructions so not shelling out 200 notes for the Sena system that fits the GT Air 2. From what I can gather I'll have to Heath Robinson something up to fit around the Sena lumps Shoei put on.
- Has thanked: 87 times
- Been thanked: 135 times
Re: Shoei GT Air 2
I have a GT air with al el cheapo bluetooth comms kit I fitted, really happy with it. The lining comes out quite easily so you can run the wires between the shell and the lining neatly.
Re: Shoei GT Air 2
Ta. Is yours the original or the 2? With the 2 Shoei added big sticky out bits for the Sena system right where you would normally put a comms unit So you have to mount any other system in a different place. Hoping I can fit it behind the Sena parts nearer the back of the lid. Hoping the clamp with work there
Other than that I'm guessing fitting should be similar with my shark.
