That's not sounding like a fun morning. !MingtheMerciless wrote: Wed Dec 30, 2020 9:41 am The dog went out at 0030 this morning, promptly came in and puked on the floor which I tidied up and then couldn’t get back to sleep. Half an hour later the poor sod then projectile puked about a pint of grossness all over the kitchen floor and back door mat. More tidying up with the stench of dog puke up my nose and then to bed. Up at 0500 for the early train to work before getting off at the halfway point and riding in. It was minus 2 so a bit brass monkey’s.
- Has thanked: 6124 times
- Been thanked: 15483 times
- Has thanked: 20841 times
- Been thanked: 13650 times
Today I have serviced my toothbrush. New batteries, duracells no less, and a new genuine oral b brush head. No expense spared. Then I fixed the freezer and earnt enough brownie points for the wife to make me a sossie sarnies! What a start to the day!
- Has thanked: 19537 times
- Been thanked: 4946 times
I made a bacon and egg sandwich for breakfast - gurt lush!!
And I tried to make fudge. Not sure it's worked though
Might try a different recipe later!! LOL
My Dad has refused the Covid vaccine. He says he's 93 and too late for all that stuff to matter.
Man,he redefines the word stubborn.
- Yambo
- Has thanked: 512 times
- Been thanked: 1403 times
Not just sail boats, any old boat will do.Harry wrote: Wed Dec 30, 2020 12:45 pm Old sail boats are like old bikes, you could spend all day, every day, working on them, but there is always something else to do.
Today I've put the final coat of paint on the new cabin ceiling panels, put the final coat of bilge paint on the new battery tray (both at home), been up to the boat and test fitted a new bed end/toilet cover support (it's a small cabin with some features usually only found on bigger boats, like an electric loo!), removed some unnecessary shite where the new battery tray is going to be positioned, measured up for the second stringer for the same new battery tray, came back to the house, sanded and varnished the 3 bits of plywood that make up the toilet cover/bed end. With a second run up to the boat I brought the instrument panel/steering wheel box down to the house where I'll start on making a new one over the weekend when we're on a complete lockdown.
I haven't even considered starting on the rowing boat yet. When all of the new bits are made I too will be doing some re-wiring work as I'll have moved the batteries, put new lights in the cabin, fitted an inverter to run off the solar panel I fitted earlier in the year etc. The end is in sight but only if you can see the future.
To be honest though I enjoy the work. The pain is having the boat at the far end of the village and only being allowed out for 3 hours a day. Oh, and breaking that 3 hours a day rule.
Wreckless Rat
- Has thanked: 666 times
- Been thanked: 704 times
The two happy days of boat ownership...
The day you buy it....
The day you sell it....
Old but true....
Old but true....
- Yambo
Not true if you've made the boat yourself.Wreckless Rat wrote: Wed Dec 30, 2020 1:50 pm The two happy days of boat ownership...
Old but true....
There is only one thing better than being a couple of miles offshore in a boat you made yourself.
Making it back to dry land without sinking?Yambo wrote: Wed Dec 30, 2020 3:18 pmNot true if you've made the boat yourself.Wreckless Rat wrote: Wed Dec 30, 2020 1:50 pm The two happy days of boat ownership...
Old but true....
There is only one thing better than being a couple of miles offshore in a boat you made yourself.![]()
- Yambo
Aye, that's the one!weeksy wrote: Wed Dec 30, 2020 3:21 pmMaking it back to dry land without sinking?Yambo wrote: Wed Dec 30, 2020 3:18 pmNot true if you've made the boat yourself.Wreckless Rat wrote: Wed Dec 30, 2020 1:50 pm The two happy days of boat ownership...
Old but true....
One with no holes in it?Yambo wrote: Wed Dec 30, 2020 3:18 pmNot true if you've made the boat yourself.Wreckless Rat wrote: Wed Dec 30, 2020 1:50 pm The two happy days of boat ownership...
Old but true....
- Been thanked: 2725 times
Helped starting to clear a ruin on spawn's croft and then down to the tip with it
Came back from the tip with another pressure washer, a CO2 fire extinguisher, a couple of 600x400mm eurocrates, a plastic pallet and a couple of roasting pans.
- gremlin
- Has thanked: 1102 times
- Been thanked: 5872 times
Tried to figure out why the roof is leaking in the summerhouse*. I can see it's damp at the rear, but looking at the bitumen shingles and guttering I can't see owt wrong. Weird.
I suspect the spring may see me pulling all the shingles off and doing the whole thing again. Another arse ache I really don't need.
*or 'shed' if you're working class like me.
Awesome - the fudge worked!!! There is even a hint of the Genepi flavourNoggin wrote: Wed Dec 30, 2020 11:52 am I made a bacon and egg sandwich for breakfast - gurt lush!!
And I tried to make fudge. Not sure it's worked thoughMight try a different recipe later!! LOL
- Yambo
Most boats have lots of holes in them Skub. My rowing boat has a long hole in the bottom of it - about 40 mm long x 12 mm wide - I can sail it if I take the notion and that hole/slot is where the dagger board goes. My big boat has holes in the hull for the toilet - inlet and waste, sink waste, bilge pump, anchor locker drain etc. Both of my kayaks have 3 big holes in the deck. On of the big holes is so that the user can sit in the boat.
Another joke: Do you want to make a small fortune? Start with a big fortune and buy a boat!
That's put me off boats even more.Yambo wrote: Wed Dec 30, 2020 4:28 pmMost boats have lots of holes in them Skub. My rowing boat has a long hole in the bottom of it - about 40 mm long x 12 mm wide - I can sail it if I take the notion and that hole/slot is where the dagger board goes. My big boat has holes in the hull for the toilet waste, sink waste, bilge pump, anchor locker drain etc. Both of my kayaks have 3 big holes in the deck. On of the big holes is so that the user can sit in the boat.![]()
Another joke: Do you want to make a small fortune? Start with a big fortune and buy a boat!![]()
Royal Navy Submarines are like sharks.
Prowling silently through the deep, mercilessly hunting prey? No...if they stop moving, they sink and die.
That's kinda like me,except even when I move I sink and die. I specialise in the anchor stroke.Mr. Dazzle wrote: Wed Dec 30, 2020 4:34 pmRoyal Navy Submarines are like sharks.
Prowling silently through the deep, mercilessly hunting prey? No...if they stop moving, they sink and die.![]()
