Triumph Thunderbird
- Cousin Jack
- Has thanked: 2901 times
- Been thanked: 2473 times
Triumph Thunderbird
Anyone know anything about Triumph Thunderbirds, the 885 cc version? Seen one locally that looks ace, but it is somewhat elderly.
- Has thanked: 623 times
- Been thanked: 9345 times
Re: Triumph Thunderbird
My dad had a Thunderbird Sport for many years, when he couldn't hold it up with my mother on the back he fitted a chair.
As far as I know the motor is pretty bullet proof if you keep the battery topped up so it doesn't spin back and knacker the spag clutch. The Sport was a very heavy motorcycle, so I imagine the standard Thunderbird is just as heavy if not more so.
- Has thanked: 2784 times
- Been thanked: 3430 times
I had one, N reg 96 I think. British racing green. Different pipes on mine and sounded fantastic when winding it up. However, had a terrible wobble from about 70/80. Bloody frightening and got rid.
- Ditchfinder
- Has thanked: 855 times
- Been thanked: 1058 times
Get on the t300 FB groups lots of advice on there, but don't try and start it with a duff battery.
You can put the cams in from other triples to up the power, carbs might need bigger jets, but if it's the single front disc version you might not want to.
Coils can go dodgy as they're getting on now but there are coil over plug conversions available.
If it cuts out when hot it's usually the crank position sensor.
Check inside tank for rust and make sure the pipes are not rotten, especially the headers as those can be harder to find.
Neutral switch might not work but can be bodged with a washer most of the time.
Rear calipers usually need a rebuild if been sat.
- Ian
- Has thanked: 1309 times
- Been thanked: 558 times
Don't know Thunderbirds specifically but a guy up the road from me said his 855 trident was unmanageably tall and top heavy (and he's a lot taller than me) so if it's the same frame get a ride on it first
- Ditchfinder
They are a bit top heavy but I'm 5'7" and I can manage. They are a pain if you have to push them around a lot but once up to walking pace they are fine.
- Has thanked: 20506 times
- Been thanked: 13425 times
I had a 865 Thruxton and loved it and was very sorry to see it go. One of the few bikes you can ride and know what your riding just by the exhaust note, something I never get from Jap bikes.
