What kit (not clothing) do you take
Hi..
So what do you take in your "tour kit " I thinking .
Few spanners / screw drivers
Replacement fuses
Bulbs if you're not led lights
Chain lube
Bit of oil
What else do you throw in?
Or are you an " overseas breakdown cover / credit card only " tourer?
Replacement fuses
Chain lube
Bit of oil
- Been thanked: 9495 times
Re: What kit (not clothing) do you take
A copy of my travel insurance/breakdown cover.
If I need anything else when away I'll just buy it (that goes for underpants too).
I took a mini can of chain lube away once. It rained almost everyday and I did 2,800 miles in 12 days. The lube lasted three days.
It's one of the reasons I only tour on cardan drive bikes now.
- Has thanked: 10959 times
- Been thanked: 3995 times
In all seriousness, I tend to carry stuff like that on the bike anyway, breakdowns happen anywhere, not just when you're on holiday, so I don't change the kit, but I will carry paperwork I might not carry day to day.
- Has thanked: 2852 times
- Been thanked: 3504 times
Puncture repair, cable ties, biscuits that don't melt.
- Has thanked: 8035 times
- Been thanked: 5693 times
When I was doing it....the legally required stuff, wally vests, spare bulbs, triangle etc. as per the countries en route.
Basic tool kit.
Puncture repair kit + small 12v pump.
(Luggage space wasn't usually a problem...apart from when we rode to Germany via Belgium, France, Luxembourg - to get some luggage fitted
Then it was spare underwear and toothbrushes
Basic tool kit.
- Has thanked: 602 times
- Been thanked: 4528 times
Puncture repair kit and a credit card, on a newish bike what are going to be able to fix by the side of the road?
- Has thanked: 12605 times
- Been thanked: 8536 times
I've been touring 40 years.
Couple of screwdrivers. Hex keys. That's it. Pliers.
Never needed any of it.
Cleaning hands!
(And arse if stuck by the road for many hours, i presume!)
FWIW, in the UK, a good handful of roadside grass will get most of the crud off your hands.
- MyLittleStudPony
- Has thanked: 829 times
- Been thanked: 586 times
I insist on few things but must have good lighting and vintage Taittinger.
- Trinity765
- Has thanked: 3138 times
- Been thanked: 3188 times
Most of the above minus triangle, biscuits and bulbs plus an emergency medical kit.
While I have never had to fix a puncture on my own bike, I have loned others my repair kit. Apart from that, I used a small square of gaffer tape last year on the off switch of my satnav.
But if you don't take it, that's when you will need it
- Ditchfinder
- Has thanked: 861 times
- Been thanked: 1069 times
The toolkit supplied by the factory plus zip ties, tyre repair kit, spare tube and inflator. I have a spare headlight bulb, a relay and I need to add some fuses. There's a spare clutch cable zip tied to the one in use. Anything more than that and all I will need is a box of matches / lighter.
Chapeau!Ditchfinder wrote: Tue Apr 21, 2026 11:45 am The toolkit supplied by the factory plus zip ties, tyre repair kit, spare tube and inflator. I have a spare headlight bulb, a relay and I need to add some fuses.There's a spare clutch cable zip tied to the one in use. Anything more than that and all I will need is a box of matches / lighter.
- Has thanked: 4088 times
- Been thanked: 2513 times
I take the same kit that I use over here,12v compressor & puncture repair kit plus a few spanners.I also take out a European breakdown policy.
The worst experience I've had was getting a knackered Kawasaki Z650 back from Barcelona to Lancashire.Somewhere in Germany the clutch cable snapped,I got that sorted then in the middle of Barcelona the fuel tap started pissing fuel all over the motor.A local bike shop plastic welded a fuel tap from a Yamaha XS 400 twin,charged me nothing then a few days later it started using lots of oil & running on 3 cylinders.I managed to nurse it back home & strip it down.A valve stem oil seal had failed
Lesson learned? It's a good idea to take a reliable bike...
