Small sized 12v compressor?
- Has thanked: 20853 times
- Been thanked: 13669 times
Back on the old place someone had a nifty little 12v compressor. It was a vey neat, small size that you could secrete away under the seat type-of-thing? Anyone got anything small sized but capable of getting up to 40ish psi now?
TIA
TIA
- Has thanked: 6125 times
- Been thanked: 15488 times
Re: Small sized 12v compressor?
wonder if the MTB versions would work for you?Taipan wrote: Mon Feb 16, 2026 1:00 pm Back on the old place someone had a nifty little 12v compressor. It was a vey neat, small size that you could secrete away under the seat type-of-thing? Anyone got anything small sized but capable of getting up to 40ish psi now?
TIA
https://www.cyclingweekly.com/group-tes ... -available
Yes, i think they would. If I did get (yet another bastard) puncture, its just got to get enough air into the now plugged tyre to get me to a garage or home. They look bang on in terms of size and my kids are pressing me for a birthday prezzie idea, so thsi will fit the bill I reckon. Cheers.weeksy wrote: Mon Feb 16, 2026 1:05 pmwonder if the MTB versions would work for you?Taipan wrote: Mon Feb 16, 2026 1:00 pm Back on the old place someone had a nifty little 12v compressor. It was a vey neat, small size that you could secrete away under the seat type-of-thing? Anyone got anything small sized but capable of getting up to 40ish psi now?
TIA
- Has thanked: 12605 times
- Been thanked: 8535 times
- Has thanked: 778 times
- Been thanked: 3216 times
I've got a couple of no name rechargeable ones from the rain forest, neither have let me down, both will do 40psi easily bit I've no idea if they go to 60.
But I do see that Noco now dabble in the compressor market, and they're a decent brand.
This one seems to have the best capacity, which I reckon would suit a motorbike tyre best?
https://www.teamcycles.com/tools-mainte ... 186741281f
Don't forget to work out if that fixed 'hose' will snake behind your brake discs and get onto the valve..
Good call. Fortunately its got side exit valves, so it shouldn't be a problem.MrLongbeard wrote: Mon Feb 16, 2026 2:01 pm Don't forget to work out if that fixed 'hose' will snake behind your brake discs and get onto the valve..
The Harley is a shit for it, I took a pair of 90 degree stems to the tyre shop when it had new rubber fitted, but totally forgot about them so in my spares drawer they sit.
- Ditchfinder
- Has thanked: 861 times
- Been thanked: 1069 times
I got one of these of Alibay https://www.ebay.co.uk/itm/326720051795 ... R47rme-MZw
They're not as small as the bike pumps but it did inflate a himalayan rear tyre from flat to 30psi on half a charge.
- wheelnut
- Has thanked: 929 times
- Been thanked: 917 times
I could be (and probably am) wrong, but I'm not so sure it will do a motorcycle tyre, at least from flat. The pressure is lower but the volume is a lot more.Taipan wrote: Mon Feb 16, 2026 1:59 pm This one seems to have the best capacity, which I reckon would suit a motorbike tyre best?
Similar reason a compressor for a car tyre won't pump my padddleboard up to 20psi.
That was my concern too, hence going for the bigger capacity one...wheelnut wrote: Mon Feb 16, 2026 3:10 pmI could be (and probably am) wrong, but I'm not so sure it will do a motorcycle tyre, at least from flat. The pressure is lower but the volume is a lot more.Taipan wrote: Mon Feb 16, 2026 1:59 pm This one seems to have the best capacity, which I reckon would suit a motorbike tyre best?
Fast Inflation: Inflate up to four 29" MTB tyres or three 700x28mm road tyres in seconds on a single charge.
High Pressure Capability: Delivers a maximum pressure of 120 PSI (8 bar), suitable for a wide range of bikes.
- Has thanked: 8034 times
- Been thanked: 5692 times
I think the neatest one I've had (and it worked really well) came supplied with an MX5. They're a silly price if you do buy a branded Mazda one but I notice someone selling the whole kit in the original bag, including gloop etc for £25 on eBay. (Mazda want over £100 for one!
Kids gave me one for my birthday. I should let my tyre down and see how far towards 42psi it can get at some point...
