Posts: 17501 Joined: Sat Mar 14, 2020 1:04 pm
Has thanked: 627 times
Been thanked: 9495 times
Post
by KungFooBob » Tue Mar 03, 2026 9:31 pm
I could google this, but it's more fun getting the info from here
I spotted this Douglas Dragonfly on FriendFace Marketplace.
Why does it have three carbs and what is the middle carb feeding?
https://www.facebook.com/share/17tm3McZzw/
Posts: 15905 Joined: Mon Jul 19, 2021 4:59 pm
Has thanked: 8035 times
Been thanked: 5693 times
Post
by Count Steer » Wed Mar 04, 2026 8:25 am
Dodgy69 wrote: Wed Mar 04, 2026 8:05 am
Special init...Google says.
Indeed....but how the heck does it feed into the cylinders?
I thought it might feed premix into the two main carbs but I can't see how.
Supposed to be part of the mods to make it a 100+ mph bike. Not sure I'd want to be on it!
Ian
Posts: 726 Joined: Tue Jul 18, 2023 9:25 am
Has thanked: 1361 times
Been thanked: 578 times
Post
by Ian » Wed Mar 04, 2026 10:55 am
That front 'mudguard' appears to lack any bracing. It makes me nervous that it could tuck under and come into contact with the tyre at which point it will get dragged under.
Oh well the accident is sure to get views and likes so it's all good
Posts: 14892 Joined: Mon Mar 16, 2020 5:32 pm
Has thanked: 13109 times
Been thanked: 14170 times
Post
by Skub » Wed Mar 04, 2026 11:39 am
KungFooBob wrote: Tue Mar 03, 2026 9:31 pm
Very odd. I'd be interested to know how it works.
Post
by KungFooBob » Wed Mar 04, 2026 12:08 pm
Skub wrote: Wed Mar 04, 2026 11:39 am
It looks like the centre carb fed a plenum behind the block, which then fed both cylinders, you can see the intake pipes in this pic...
I guess putting a separate carb on each inlet improves performance, but you'd think the centre carb would then be removed?
Post
by Skub » Wed Mar 04, 2026 1:09 pm
I had a yarn with our local Brit fiends. We all assumed it was a 3 carb bike,but it's actually a twin carb conversion. The carb in the centre was the original and the one on the right cylinder is the extra. You can see where the manifold was blocked off. So middle carb still feeds the left pot and the new one feeds the right.
dragonfly manifold.jpg (38.58 KiB) Viewed 903 times
Post
by Count Steer » Wed Mar 04, 2026 1:43 pm
I wondered about that blanking plate but couldn't see from the pix if there was an equivalent on the other side.
Post
by KungFooBob » Wed Mar 04, 2026 1:43 pm
The other pot has a carb too...
Post
by Count Steer » Wed Mar 04, 2026 5:07 pm
KungFooBob wrote: Wed Mar 04, 2026 1:43 pm
So all is clear then.
Blanking plate on that side too.
I couldn't see how the central carb was possibly connected to either the cylinders or the carbs when it feeds into that housing and the housing isn't connected to either - and the answer is - it doesn't, but it used to. So it's now a spare.
Had me head scratching last night though!
Post
by Skub » Wed Mar 04, 2026 5:20 pm
It's like the V-Max with it's fake air intakes. Even the classic boyos are at it now.
Post
by Skub » Wed Mar 04, 2026 8:27 pm
He definitely has an account with Ali-express.
Posts: 9039 Joined: Tue Mar 17, 2020 4:05 pm
Has thanked: 2288 times
Been thanked: 2673 times
Post
by ZRX61 » Wed Mar 04, 2026 11:16 pm
Skub wrote: Wed Mar 04, 2026 8:27 pm
Those rear-sets look more like they came from Temu...
Post
by Skub » Sun Mar 08, 2026 5:54 pm
Panther special.
Panther special.jpg (98.09 KiB) Viewed 678 times
Post
by Count Steer » Sun Mar 08, 2026 6:46 pm
Skub wrote: Sun Mar 08, 2026 5:54 pm
Panther special.
Seen it all now. A café racer Panther!
...with disc brakes too!
Nobby
Posts: 802 Joined: Sun Mar 15, 2020 5:04 pm
Has thanked: 175 times
Been thanked: 766 times
Post
by Nobby » Mon Mar 09, 2026 11:47 am
The centre carb is for the auxiliary engine that runs the Aircon, hydraulic pumps and electrics.
