Interesting bicycles found on the internet.
- Has thanked: 2572 times
- Been thanked: 6303 times
Re: Interesting bicycles found on the internet.
You don't need that many stacks of gears to get lots of ratios. One cluster can do up to four ratios...two together can do up to 16...four lots of four...and so on.
Not all of those will be useful and some will be reverse. It may not be possible to actually make all of them work for mechanical reasons either. But you can see that lots of ratios is possible.
Edit : the reason I previously said three and not four is that the fourth ratio is just the whole unit - housing and all - going around as one lump. So its probably fairer to say three ratios.
- Has thanked: 609 times
- Been thanked: 4133 times
I do wonder how many gears a bicycle actually needs, I had bikes with the Sturmey Archer 3 speed hub, and after having a single speed bike they were amazing, I then had a 5 speed derailleur bike, this was a benefit over the 3 speed, but I used to use, top, middle and bottom, a 10 speed just gave you a higher top gear. I think you only need 5 widely spaced gears, but because of the way derailleurs work you have to have a load of gears in between to make gear changes possible.
- Has thanked: 5472 times
- Been thanked: 13170 times
That depends where you ride and what you're riding on.Le_Fromage_Grande wrote: ↑Thu Dec 24, 2020 10:44 am I do wonder how many gears a bicycle actually needs, I had bikes with the Sturmey Archer 3 speed hub, and after having a single speed bike they were amazing, I then had a 5 speed derailleur bike, this was a benefit over the 3 speed, but I used to use, top, middle and bottom, a 10 speed just gave you a higher top gear. I think you only need 5 widely spaced gears, but because of the way derailleurs work you have to have a load of gears in between to make gear changes possible.
I can pretty much say that every time i go out i'll use the top and bottom of my cassette and most of the ones in the middle. How many i could get away with dropping in the middle though, i'm not quite sure.
That's true, it also depends on how you ride, when I used to use a clockwork bike for MTB I probably used 5 gears, but I'm not someone who's that bothered about my pedalling cadence, and now I have an EMTB the motor makes gear selection less important as the motor adjusts how much power it puts in according to pressure on the pedals. (I've ended up riding in a lower gear than I used to because the motor seems to like a faster cadence than I used to do)weeksy wrote: ↑Thu Dec 24, 2020 10:47 am
- Mr Moofo
- Has thanked: 1849 times
- Been thanked: 1482 times
I find my self more and more attracted to a BTR - not that I could use it properly
Interesting high pivot and chain tensioning system there.
- MingtheMerciless
- Has thanked: 2963 times
- Been thanked: 1893 times
The LBS had a few high pivot and idler gear bikes from a less well known brand a few years ago, everyone that rode it raved about the rear suspension performance and how well the bike went over bumps (rear travel was diagonally backwards and up rather than just up apparently) but as it wasn’t a well known boutique brand and wasn’t made from burnt toast and horse hair I don’t think they sold too many. Interesting that Trek are now looking at it.
- Has thanked: 1361 times
- Been thanked: 1749 times
AS it's Trek month on the forum... i've got the new Fuel EX to view.
That is very very good looking and I bet it works brilliantly.
They could have quite easily closed up that space above the BB with a door/cover on the non drive side, and it would have been the perfect size for a tube & inflator.
- Mr Moofo
^ that is actually a nice looking bike
Shame they can't do anything about the riders
Gamux run a VERY different frame, including a Pinion gear system.
- ChrisW
- Has thanked: 2948 times
- Been thanked: 2078 times
I've just spent two minutes trying to figure out how that works, where the shock goes...I have a head cold, that's my excuse.
