Define: huge increase in power
Has thanked: 24 times
Been thanked: 358 times
Post by ..... »
I was reading some blurb from a tuner about what they'd done to a bike (akra, air filter and ecu flash)
So after spunking the best part of a grand on bits, anyone care to guess what % or hp gain they received, described by tuner as a 'huge increase in power'
I know that my bike, with the older version of the same engine actually dyno'd slightly higher with pipe, filter, airbox mod and flash, and allegedly, has a lower initial output, so a bigger gain (i only paid for the flash and air filter)
Has thanked: 12620 times
Been thanked: 8541 times
Re: Define: huge increase in power
What bike?
Been thanked: 9505 times
I've got a bike that had the loud pipe, K&N filter, Power Commander V and O2 sensor delete, treatment. Gave it an estimated 10% increase in power.
25bhp to 27.5bhp!
Post by ..... »
KungFooBob wrote: Wed Oct 01, 2025 9:19 pm I've got a bike that had the loud pipe, K&N filter, Power Commander V and O2 sensor delete, treatment. Gave it an estimated 10% increase in power.
25bhp to 27.5bhp!
No dyno to back it up, just barstool bull ;)
Post by ..... »
Yorick wrote: Wed Oct 01, 2025 9:17 pmWhat bike?
Full on sports bike >800, <1000
It's all subjective tho init.
10% is a huge 20bhp if you start with 200bhp.
If you start with 10bhp it's only 1bhp.
Post by ..... »
Thats why I gave the option of % increase or actual hp.
When we had Bob Farnham tune our GT50, He claimed ,and I have no reason to dispute this, to have doubled the power of the beast from 3 to a solid 6 or so. So I understand that 3hp can be a 100% increase
But... is 1bhp noticeable if you only start with 10bhp?
You've got to notice 10% more power, right?
Would you notice 1bhp if you had 100bhp to start with?
Mike1976
Has thanked: 4 times
Been thanked: 28 times
Post by Mike1976 »
"akra, air filter and ecu flash" that's going to do a lot more than just add numbers. It will make the engine more responsive, better throttle response, shift the peak torque (hence more power aka more speed). Never worried much about fuel consumption myself but that should also be better since the engine is effectively more efficient.
Now I think about it, I'm not so sure about the last one. You could easily trade in mpg for mph I suppose. Anyone know?
..... wrote: Wed Oct 01, 2025 9:14 pm I was reading some blurb from a tuner about what they'd done to a bike (akra, air filter and ecu flash)
None of this makes any sense.
Has thanked: 7636 times
Been thanked: 5937 times
As an aside, are those Treetop / Hilltop people still working their magic?
Post by ..... »
KungFooBob wrote: Wed Oct 01, 2025 9:59 pm But... is 1bhp noticeable if you only start with 10bhp?
Do you deliberately try and be obtuse, or is it a default setting?
Been thanked: 4529 times
A huge increase in power has to be at least 50%, I've only ever seen these sort of increases on road going 1980s bikes converted to race bikes and with engines that last as long as race engines, for example you can get 140bhp from a 1985 GSXR750 that originally put out about 90bhp, but you can't get 300bhp from a 200bhp R1. 350LCs weren't particularly difficult to get a 50% increase from, but the pistons didn't last long.
A_morti
Has thanked: 412 times
Been thanked: 824 times
Post by A_morti »
..... wrote: Wed Oct 01, 2025 10:44 pm Do you deliberately try and be obtuse, or is it a default setting?
Says the OP of this thread.
Anyway. Is it an fz1 gaining 8 horsepower?
And are you screwd?
McNab
Has thanked: 261 times
Been thanked: 319 times
Post by McNab »
So what is it then?
Tricky
Has thanked: 3045 times
Been thanked: 3309 times
Post by Tricky »
It's definitely not an FZ1, as they had carbs, and the OP isn't Screwd.
My money is on it being a current CP3 based bike , and if I had to guess, I'd say the OP has an XSR ( think he did also used to have a (horrid shonky looking but sorted) 1000 Fazer too? :1 ;)
Has thanked: 3650 times
Been thanked: 2505 times
According to a couple of videos I've watched ZH2's with a flash, air filter and exhaust can make between 230-240BHP from 198, however there are also stories of burning out No.3 spark plug and worse damage. So apart from the AR end can and noisy dump valve (sorry, not sorry @weeksy) I've left mine standard.
ohh look is that the ban hammer looming? 😂😂😂
Has thanked: 8048 times
Been thanked: 5699 times
Back to the original question, my guess is they're claiming between 5 and 8% as a 'huge' increase.
Been thanked: 14171 times
When I had my Z1000 de-catted,pipercross air filter and the ecu flashed,I told the guy I wasn't interested in massive gains in bhp,all I wanted was a bike with a sweet throttle and no big flat spots. Kawasaki give stock power at 140ish at the crank,the finished article punted out that figure at the rear wheel.
What's the power loss from crank to rear wheel,about 5%?
Has thanked: 1926 times
Been thanked: 1728 times
The odd thing about all these power gains, is that most of us never, ever use anything like the full potential BHP of the bikes we have.
And for the real world I would have thought concentration on low down torque would be the only thing most people could "feel"
