Electric bikes, the next step
Scootabout
Has thanked: 469 times
Been thanked: 308 times
Re: Electric bikes, the next step
Post by Scootabout »
When I tried a Vectrix electric maxi scoot back in c.2005 I was pretty impressed, and made a mental note that I'd be happy to ride something similar when the price dropped. They were ahead of their time and went bust. I've just discovered they've been revived:
https://scooter.uk.com/vectrix-vx-1/
I don't doubt electric bikes are the future - perhaps nearer than many of us think.
Scootabout
By the way, Santa kindly dropped one of https://www.decathlon.co.uk/p/electric- ... rget%20300these off early for me.
For urban use, they're brill.
Has thanked: 2632 times
Been thanked: 1498 times
Has thanked: 5504 times
Been thanked: 12762 times
Has thanked: 626 times
Been thanked: 4070 times
Would you pay £12.5K for a lardy SV650 that has to be charged overnight between rides?
Le_Fromage_Grande wrote: Thu Dec 17, 2020 3:38 pm
No, but i don't believe i'm their target market.
G.P
Has thanked: 2113 times
Been thanked: 1310 times
Post by G.P »
0I think the first Leccy motorcycle I get will be a groovy little trailie for going to the shops (pub) and playing with on the ridgeway.
like a stage 2 eMTB but without bothering with Pedals :)
Given the rights of way laws in England and Wales you'd be better off with an EMTB, you could have a derestrictor for when you want to use it on "private" land and go faster.
Has thanked: 1715 times
Been thanked: 2013 times
Thankfully, I won't need to worry about these at my age.
Scootabout
But if you assume the variable element of the running cost is 2.5p per mile plus 1p for the belt wear plus 3p for tyres, whereas the SV would be maybe 12p per mile more than that, it starts to look more comparable. Break-even would be after about 50,000 miles, I think. I'm assuming fixed costs would be the same.
Has thanked: 5945 times
Been thanked: 4933 times
Scootabout wrote: Thu Dec 17, 2020 10:15 pm
Servicing costs would be a tad lower too.
A_morti
Has thanked: 301 times
Been thanked: 542 times
Post by A_morti »
It's lighter than an sv650.
And yes, I would.
A_morti wrote: Fri Dec 18, 2020 6:43 am
And yes, I would.
It weighs 190kg, I think an SV is about 170
And on the running costs thing, if break even mileage is 50,000 miles, that's going to take a long time
Has thanked: 2611 times
Been thanked: 6015 times
Dry weight of an SV is 170kg, kerb weight is 190kg like the Zero.
Edit. Zeros website says 142kg kerb for the S...so much lighter than an SV650.
I got the 190 from the MCN report - should've known better
I reckon in any other context a 60bhp bike which weighs 140kg would have people all over it. Consider that the Duke 390 everyone loves is 10kg heavier and 15bhp less powerful. The leccy bike will be far gruntier too.
My Husqvarna 610 weighed about 140KG and made about 50BHP, it was great fun, with an electric motor you should be able to adjust the torque curve to whatever you want (within reason)
The only problems I see with the electric bike are price (it's easily twice what I'd be willing to pay for it) and refuelling, most supermotos only have ranges of about 60 miles, so this would be fine, but recharge time needs to be 30 minutes maximum.
If all the motorcycle manufacturers got together and came up with a common battery you could stop at a filling station and exchange the flat battery for a fully charged one (a similar process to gas bottles) and then the recharging problem would be solved.
A_morti
Post by A_morti »
Le_Fromage_Grande wrote: Fri Dec 18, 2020 9:21 am
And yes, I would.
Dry weight of the Zero is a claimed 142kg. I guess you have to add fork fluid and brake fluid to that and probably get to around 145kg.
Apparently Suzuki claim 197kg wet for the SV with ABS. That has to include engine oil, coolant, battery acid, fuel, fork oil, brake fluid, etc.
50kg is a really big difference.
A_morti
Post by A_morti »
Le_Fromage_Grande wrote: Fri Dec 18, 2020 11:01 am If all the motorcycle manufacturers got together and came up with a common battery you could stop at a filling station and exchange the flat battery for a fully charged one (a similar process to gas bottles) and then the recharging problem would be solved.
www.electrek.co/2020/09/04/honda-yamaha ... eries/amp/
Has thanked: 7727 times
Been thanked: 2401 times
And yes, I would.
5 years -ish? How long do people normally keep commuting bikes?
Because that's what this is - a commute bike, there's little point (at the moment) in buying a leccy bike for 'fun'*, but for saving money over the life of a commuting bike they're ideal (regular journey of known length, charged overnight etc). I'm basically waiting for these things to start appearing on the 2nd hand market**.
* opinions vary.
** - well - I was. Pandemic inspired working from home has changed commuting requirements somewhat.
