20200404_180158 by Nic Holland, on FlickrThe driveway slopes upwards towards the house. Next-door (semi so same building) has a lower drive, with some steps down to a door to access their cellar. I'd like to (probably get someone in post corona to do this) remove the window, install a door, dig out access and put a ramp + retaining walls in so I can keep bikes in the cellar.
The cellar window looks out onto a sort of walled in hole that's filled in with gravel. Other houses on the street have a sloping window bridging the gap where the hole is i.e the hole is supposed to be part of the cellar I think. Anyway at somepoint someone has put a concrete wall + upvc window in dividing that bit off, then filling in with gravel. Hopefully the photos below explain it better:
20200404_180140 by Nic Holland, on Flickr
20200404_180540 by Nic Holland, on FlickrHere's how it looks inside:
20200404_180522 by Nic Holland, on Flickr
20200404_180447 by Nic Holland, on FlickrAnyway I was thinking of making a first step at it by constructing a temporary sloping lid on it to cover the area currently full of gravel, removing gravel, knock through concrete wall, remove upvc window. The I think the next step would be getting someone in to excavate, put retaining walls , extending the small walls already there, maybe going a bit wider, put a ramp in and make good the drive to either side...
Anyone done anything similar, anything I should be looking out for, potential pitfalls etc? Possibly daft idea but seems at least possible given next door have steps down & a door...
