The answer to a problem no one had, or a great idea?
- Has thanked: 20857 times
- Been thanked: 13675 times
- Cousin Jack
- Has thanked: 3003 times
- Been thanked: 2522 times
Re: The answer to a problem no one had, or a great idea?
Good idea, as long as it only costs pence. If it is £4.99 or similar I won't be buying it.
- Has thanked: 5954 times
- Been thanked: 3572 times
It's rare to get not enough clearance between chain and swingarm for you to angle the straw almost straight down anyway surely?
- Has thanked: 778 times
- Been thanked: 3216 times
£2.93Cousin Jack wrote: Tue Sep 02, 2025 12:25 pm Good idea, as long as it only costs pence. If it is £4.99 or similar I won't be buying it.
https://darpansarvanstore.com/product/c ... zzle-tool/
- Has thanked: 2556 times
- Been thanked: 4167 times
ISTR that people are explicitly advised NOT to lube chains with the bike running on a stand, gear engaged and rear wheel turning. That advice would still apply using this gizmo.
Safety or not, I don't want to spoil a perfectly good tie.
- MyLittleStudPony
- Has thanked: 831 times
- Been thanked: 586 times
Looks like it's blowing all over the rear tyre.
It's been a long time since I lubed a chain. I used to bend the tube near the far end by about 15 degrees, then fire lube onto the chain in parallel with it, towards the front sprocket and thus away from the rear tyre.
- Has thanked: 12606 times
- Been thanked: 8536 times
I've always managed to do that with standard can ??
- Ian
- Has thanked: 1361 times
- Been thanked: 578 times
To be fair I do know someone who trapped his fingers maybe if he had one of those
...or if he wasn't a prat
- Has thanked: 245 times
- Been thanked: 1228 times
- Contact:
Looks like a load of shit to me.
Is that outside the binary of choice offered in the thread title?
It's strictly a binary choice. FFS, the last thing we need is reasoned arguments and opinions!JackyJoll wrote: Tue Sep 02, 2025 5:41 pm Looks like a load of shit to me.
- Has thanked: 2852 times
- Been thanked: 3504 times
I'll waste my pennys on something else thank you.
I don’t lube chains I just buy new ones.
Problem solved.
Or, I put it on a stand and let the rear run with the engine on about 5k, and smear grease on using my fingers.
Easy.
Problem solved.
Easy.
- Contact:
Safety tip- use someone else’s fingers.fingerpuk wrote: Tue Sep 02, 2025 7:19 pm I don’t lube chains I just buy new ones.
Problem solved.
Easy.
Modern yams throw a code/eml if the rear wheel is turning whilst the front is stationary.
Perhaps they designed it that way to encourage best practice whilst lubing a chain.
Also throws a code on the brake roller at test time if the ignition is on!
I think my AT does that. You have to turn the ABS off but I think it resets itself after a certain distance or suchlike?..... wrote: Wed Sep 03, 2025 8:16 am Modern yams throw a code/eml if the rear wheel is turning whilst the front is stationary.
ABS uses the relative speed of the two wheels as a big part of working out if the brakes are locked of course. It also does loads of error checking to make sure the sensors are working. If it sees a very large difference in wheel speed it will probably say "nah that can't be right" and turn itself off/down.
Hence the warning light.
I was under the impression that below x mph (6 iirc) abs is inactive. My abs light doesn't extinguish until 10mph is reachedMr. Dazzle wrote: Wed Sep 03, 2025 10:45 pm If it sees a very large difference in wheel speed it will probably say "nah that can't be right" and turn itself off/down.
However I have no idea what speed the rollers of an MOT station travel, or indeed what the speed is at tickover in 1st on the paddock stand!
