Metal board under window?
Mairi
Has thanked: 23 times
Been thanked: 19 times
Post by Mairi »
Moved into my new (old) house and needs a bit of fixing up.
I've been stripping the wallpaper from the spare bedroom, and under the window it's like there's a metal board? Is this normal? Do I need to get it checked out? If I need to get it checked, what trade should I be contacting?
If you look at the pic below, its the dark bits that suggest metal (the rest is that I just haven't scraped the stuff on top of it off properly yet) and if I whack it, it sounds like metal.
under window.jpeg (955.21 KiB) Viewed 1023 times
Has thanked: 8035 times
Been thanked: 5693 times
Re: Metal board under window?
Metal? It seems an unusual 'fix'.
I wonder what's underneath it?
Might just be a case of someone using what they had to hand - but a bit of coincidence that it's the right size.
Has thanked: 1059 times
Been thanked: 1646 times
The closest Ive seen on sites has been when someone wants to plaster over timber and they staple mesh over it to provide a key for the plaster.
If it was me (bearing in mind that I work on sites and am a carpenter by trade) I'd remove the trim/molding that looks to be right under the windowsill and with luck see a bit more of how it's put together.
Well, actually I'd likely poke it with a bradawl first, thats my go to pokey thing.
I've never seen nor put steel sheet under a window.
Has thanked: 781 times
Been thanked: 1072 times
Hammerite and forget about it.
Has thanked: 10959 times
Been thanked: 3995 times
Pre-prepared armoured sniper position? What's the view from the window?
Mairi
Post by Mairi »
Rockburner wrote: Thu Aug 14, 2025 7:06 am Pre-prepared armoured sniper position? What's the view from the window?
The houses across the street and the tennis club :D
cvilla
Has thanked: 1160 times
Been thanked: 438 times
Post by cvilla »
Try a magnet to see if really metal, or foil based board?
Ideally get a hole to see what is on other side, if no insulation, could be cold under the window depending on wall construction and thus get damp condensation issues. If you can add some insulation board, extend the cill with nosing may improve thermal properties a bit.
Mairi
Post by Mairi »
cvilla wrote: Fri Aug 15, 2025 11:19 am Try a magnet to see if really metal, or foil based board?
Tried the magnet trick, it's definitely metal
Has thanked: 316 times
Been thanked: 1078 times
Post by Silly Car »
Mairi wrote: Fri Aug 15, 2025 9:23 am
It probably dates back to Judy Murray’s tyrannical regime of leading Scottish Tennis training… :D
Mairi
Post by Mairi »
so, on top of that the window directly under that window is the living room bay window, the metal is there under the middle part under the window too. Maybe its just reinforcement?
Mairi wrote: Fri Aug 15, 2025 4:00 pm so, on top of that the window directly under that window is the living room bay window, the metal is there under the middle part under the window too. Maybe its just reinforcement?
You've moved into a 'safe house'. :o
It's all a Faraday cage to prevent electronic eavesdropping. :D
