They're the ones with the wet timing belt, aren't they?v8-powered wrote: Wed Jun 18, 2025 12:52 pm One of the kids has a Shitroen C3 with the 3-cylinder Puretech engine, I reckon that easily does a litre of oil in 1000miles, if not more!
Modern ICE vehicles are designed to burn oil
- Has thanked: 2558 times
- Been thanked: 4169 times
Re: Modern ICE vehicles are designed to burn oil
- Has thanked: 2852 times
- Been thanked: 1611 times
Yep - timebomb! I've recently had to remove and clean the VVT actuators as full of belt fibresmangocrazy wrote: Wed Jun 18, 2025 1:06 pmThey're the ones with the wet timing belt, aren't they?v8-powered wrote: Wed Jun 18, 2025 12:52 pm One of the kids has a Shitroen C3 with the 3-cylinder Puretech engine, I reckon that easily does a litre of oil in 1000miles, if not more!
Eek! I'd be thinking about quietly moving that on in the near future before Bad Things Happen...v8-powered wrote: Wed Jun 18, 2025 1:48 pmYep - timebomb! I've recently had to remove and clean the VVT actuators as full of belt fibresmangocrazy wrote: Wed Jun 18, 2025 1:06 pmThey're the ones with the wet timing belt, aren't they?v8-powered wrote: Wed Jun 18, 2025 12:52 pm One of the kids has a Shitroen C3 with the 3-cylinder Puretech engine, I reckon that easily does a litre of oil in 1000miles, if not more!
FWIW I'm pretty sure that checking the oil is on the driving test you know. Or at least, it's one of those things they might ask.
https://www.gov.uk/government/publicati ... -questions
Equally FWIW I can't remember the last time I needed to top up the oil in a car. They might say a litre every 1000 miles but that's not been my experience. The only car I can recall burning oil in any serious way was Mrs. D's old Civic Type-R, which ironically has a famously very good engine!
My last 2 cars have been brand new and I took precisely zero care to run them in (even the dealer said "don't worry about it"). Neither have burned even a tiny bit of oil so far as I can work out, but I check electrically not with a dipstick.
As has already been mentioned, babying an engine during running in is probably the worst thing you can do. Boot them from the get-go and the rings will bed in properly to the cylinder walls and all will be well.Mr. Dazzle wrote: Wed Jun 18, 2025 2:13 pm My last 2 cars have been brand new and I took precisely zero care to run them in (even the dealer said "don't worry about it"). Neither have burned even a tiny bit of oil so far as I can work out, but I check electrically not with a dipstick.
Yeah I've heard that story loads too. My main takeaway is always that most people don't get what the honing on a cylinder is actually supposed to do.
I didn't boot it from scratch either TBF, I just drove normally. They were auto too, so you'd have to go out of your way to rag 'em against the rev line or anything like that. S'also a >300bhp car so there aren't that many chances to hoof it in southern England at rush hour, which is when I drive the car.
My anecdotal evidence is from when I bought my 690 Duke in 2017. As soon as I got it, I dumped the oil, changed the filters and put running-in oil in the engine, then revved the engine 'briskly'. I didn't red line it, but gave it plenty of revs in the lower gears. By the time it went in for its first service (where they filled it with top spec 10w60 fully synth) it was effectively run in. It doesn't use any oil between services, which is unusual for Duke 690s, I've been told.
Beancounter
- Has thanked: 3130 times
- Been thanked: 684 times
Add in lack of confidence and fear of making the problem worse and I think that contributes to why a lot of people don't do things themselves.Jody wrote: Wed Jun 18, 2025 10:26 am It's not lazy imo, it's a lack of understanding. The car works, they are not interested in cars, so they just carry on.
Do you know how to service your washing machine and how often to change the filters and belts..... or are you a lazy feckless tosser ??
We want to brick pave the back garden. I've watched several Youtube videos on it but am still shying away from attempting the job myself in case I fuck it up and it costs me more to put right.
- Has thanked: 10971 times
- Been thanked: 4004 times
Yup, it's why I'm taking the JAPton crank to a specialist. In paper it looks possibly doable, but I'd really hate to make a rookie mistake with it.Beancounter wrote: Thu Jun 19, 2025 11:38 amAdd in lack of confidence and fear of making the problem worse and I think that contributes to why a lot of people don't do things themselves.Jody wrote: Wed Jun 18, 2025 10:26 am It's not lazy imo, it's a lack of understanding. The car works, they are not interested in cars, so they just carry on.
- Been thanked: 2730 times
And don't forget tooth sucking professionals making everything sound much more complex and or risky than it is.
Beancounter
Yes, a lot do play on customers' fears/need for validation.cheb wrote: Thu Jun 19, 2025 1:35 pm And don't forget tooth sucking professionals making everything sound much more complex and or risky than it is.
And it has to be said that opening the bonnet on a modern car all you will see are acres of plastic, with virtually all the components hidden/out of sight. Not exactly encoraging to any would-be rookie mechanic.
- Cousin Jack
- Has thanked: 3016 times
- Been thanked: 2528 times
You can polish the plastic nicely.mangocrazy wrote: Sun Jun 22, 2025 12:18 pm And it has to be said that opening the bonnet on a modern car all you will see are acres of plastic, with virtually all the components hidden/out of sight. Not exactly encoraging to any would-be rookie mechanic.
- Has thanked: 19612 times
- Been thanked: 4960 times
I'm embarrassed to admit that I didn't check the oil in my car from when I bought it until the oil warning (not light, a message
) came on last week
It's done 12,000kms since January but mostly booting up and down a mountain (approx 1400m altitude) but I was still a bit surprised.
Have topped it up and now waiting for a time when everything is properly cold and I can dip it again - cos even when it dipped it when it hadn't been running, the outside temps were 35 degrees, so I wasn't sure that was a good thing either !!!
NVH covers. Gets surprisingly louder when you take them off!mangocrazy wrote: Sun Jun 22, 2025 12:18 pm And it has to be said that opening the bonnet on a modern car all you will see are acres of plastic, with virtually all the components hidden/out of sight. Not exactly encoraging to any would-be rookie mechanic.
- Has thanked: 780 times
- Been thanked: 3224 times
The important stuff is usually yellow or blue so obvious to check.
And checking the oil has been part of the test for a while so should be being taught by instructors if the parents haven't
Check your book, some should be checked hot after a journey.Have topped it up and now waiting for a time when everything is properly cold and I can dip it again - cos even when it dipped it when it hadn't been running, the outside temps were 35 degrees, so I wasn't sure that was a good thing either !!!
I will do that. I've never heard of that before, but would make it easier to check here !!!!MrLongbeard wrote: Sun Jun 22, 2025 4:54 pmCheck your book, some should be checked hot after a journey.Have topped it up and now waiting for a time when everything is properly cold and I can dip it again - cos even when it dipped it when it hadn't been running, the outside temps were 35 degrees, so I wasn't sure that was a good thing either !!!
(Never been very good with RTFM!!)
Yeah it was a new one on me a while back, after 2 civics, 1 mini and 1 Harley it's second nature to rtfm and check if it should be done hot
- Has thanked: 222 times
- Been thanked: 788 times
Does a 2008 Clio Campus count as modern? My other vehicles are respectively 59 and 68 years old...
any hoos...the 120,000 mile campus use no oil even after 85mph abuse on one of the hottest days of the year...and it's a 1,2 petrol....
