Schwalbe Albert tyre mini review
Has thanked: 3644 times
Been thanked: 2502 times
So I got hold of a pair of the "radial" Alberts for the Epocalypse, gravity sidewalls, 2.6, 29er flavour. Ultra soft front, soft rear.
Straight out the box on my local trails I pretty much equalled my Strava PBs on my favourite trails in Friston, first time on singletrack after winter with so-so fitness and I've detuned the speed box from unlimited to 20mph over winter to extend the battery range.
The front grip is very good on South Downs hardpack, almost bottomless. I kept going into corners at my usual "max" pace and realising that I could've carried more speed into them. Very confidence inspiring. Rooty sections could be ridden pretty much as if they weren't there (let's see what they're like in the damp and wet).
We then had 4 days on Dartmoor where the grip on the very dusty/ dry conditions was outstanding with the only front end slides being me deliberately provoking them. Even on the wetter trails (streams occasionally borrow a bridle path for their route) the grip was very good. Grip on granite was outstanding, I had a bike technology saving me moment when the DH track that I was on had a new route that turned into a bloody steep 10ft granite block to loam section that the bike just laughed off.
Back in a perfect Friston today, I had two hours at flat chat for me, equalling many PB's and a few improvements. As I got tired I had a few "drop the inside shoulder" front tucks and got away with all of them. I'm utterly fried typing this, I got home with both the battery and me in the red)
I'm sold on them, I feel that the front has a much more to give grip wise (I was running an assagai before), the rear is fine but trail braking at extreme angles it can be lock up a bit snappily, more so than the Minion DHR it replaced.
Pressures, internet seems to think start 5 psi above your normal pressures and fiddle from there, after fiddling I'm at +4psi so 25F and 27R.
Has thanked: 1926 times
Been thanked: 1728 times
Re: Schwalbe Albert tyre mini review
Shame I am not good enough to notice the difference
Very very interesting. I believe we had the wrong rubber when he tried the Radial
mboy
Has thanked: 854 times
Been thanked: 696 times
Post by mboy »
@weeksy what was James running again...? Remind me why he didn't get on with them...
@MingtheMerciless positive stuff! All very useful feedback, and sounds similar experience to just about everyone else who's tried them... Good that you went straight in with the higher pressures, does take a LOT of convincing to try this with some people, their prejudices make them quite reluctant to try it, but I find 20-25% higher pressures than you'd normally run is the sweet spot... I've settled on 26F and 29R myself for now, up from 22/25 on a normal carcass.
mboy wrote: Mon Mar 31, 2025 10:22 pm @weeksy what was James running again...? Remind me why he didn't get on with them...
He ran a pair of Shreddas in the softest grippiest compound. His feeling was at the time he had less grip, but more rolling resistance. So they didn't last long. As always, he/we didn't give them a lot of test time in truth, but that's the nature of him (and us/me) in the fact that all sessions/riding is targetted and we always have something we're working on. This was the day before a race so the priority was putting in fast laps on the race track. It arguably wasn't the best day/timing but the conditions were pretty awful so should have suited them well.
Albert Soft/trail casing now fitted to the front of the Curtis. Rear only takes a 2.3 so can't fit another. First time out equalled or bettered PB's on my favourite trails. More pressure tweaking required, it's very noticeable how much more compliant the front is compared to a Kenda Regolith rear. @mboy I need a 2.3 trail casing fast rear tyre like a Small block 8 or Honey badger type pattern.😂
https://www.pinkbike.com/news/specializ ... ineup.html
It seems Specialized have jumped on the Radials now as well. I quite like a Spec tyre at times, so i'm not against giving these a whirl. I liked them more when they used to knock them out for £20 though :D
